P38 Factory Winch Install Warn XD9000 CE
6 replies to this topic
Teds
Teds
    WJ6SPK
  • 904 posts
  • 2001 Range Rover
  • 2009 M1101 trailer
I bought a factory P38 winch tray and Warn XD9000 CE winch from a guy selling his P38 on craigslist a few weeks ago. I finally got around to installing it this weekend and of course, it took me much longer than expected. I also ran into a few differences from the factory instructions. The most notable being the bracket to hold the selenoid pack does not fit on a 2001 RR because the secondary air injection pump is right where the end of the bracket should be. The truck I took the winch off of was a 98 (GEMS) and had plenty of room there, right next to the fusebox. I mounted the selenoid pack underneath the fusebox and drilled an extra hole in the post holding the fusebox. It is a tight fit but seems to work and gives enough length to run the wires to the winch. The other issue I had was that I made the slats in the bumper too small (yes, you have to cut the bumper) and cutting the bumper while mounted to the truck is much harder than when it is off.The winch i got was in fantastic shape and the tray just had some minor surface rust. I spent some time cleaning it up and repainted it hammer finish black to match my sliders. We will see how long the finish will hold up. You can also still see some surface rust on the fairlead that I will bead blast in the future when I get a synthetic rope.
Some pics:
Bumper and brushbar removed:
Bumper for cut-outs:
Right bracket attached with wiring. The wiring was ultimately re-routed to the left and higher to come out near the front fans. The yellow plate is the Southdown front steering guard.
Left bracket attached:
Selenoid pack under the fusebox:
Winch installed!
with the factory front winch cover:
The front cover is missing a few of the spring bolts for attachment. If anyone knows where I can get some, I would appreciate it. I will go to Lowe's but they don't look common and with all things rover, they will probably be impossible to find.
I will try and get some pics in the light. I finally finished about 10pm last night!
  • 4,788 posts
Nice work. Where did you install the remote wire control outlet eg dash, hood?
Teds
Teds
    WJ6SPK
  • 904 posts
  • 2001 Range Rover
The remote winch control is only used when I am using the winch. There is a connection on the left side of the winch that I hook into and the remote has a cord about 15? feet or so. It is not always connected and there is no wireless control, not that I would trust a wireless control in the field.
Nice... What spring clips are you talking about?
AA Journey
AA Journey
  • 592 posts
Looks good Ted. Did that take some of your approach angle or is level to the fog lights? Will check it out in DV.
Antonio
KK6KSO
2011 LR4 LUX
"Of all the paths you take in life make sure a few of them are dirt”
John Muir
MichaelBeaver
MichaelBeaver
  • 426 posts
Did your P38 have any withdrawals or rejection issues since this was not an ARB product? ;P
Beaver (Twitter: @darthbeaver)
LR Street Cred:
2000 Discovery II - 3" TerraFirma Lift, AMV solenoid CDL, BajaRack Expedition Rack, Dual Battery
2010 Range Rover Sport
1990 RRC Trailer "Land Trailer"
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Dream. Explore. Discover." ~ Mark Twain
Teds
Teds
    WJ6SPK
  • 904 posts
  • 2001 Range Rover
Ha! Its not ARB, but it is factory OEM. The only ARB component I have is my beloved fridge...
Yes, it does take away a bit of approach angle as it sticks out under the bumper. But I feel the benefits of a winch out-weigh the loss in departure angle.
I will take a pic of the spring/clips soon. It is a bolt that goes through the plastic cover and then screws into this spring/clip attached to the winch tray. Hard to describe, but simple tool.
