So close...
70 replies to this topic
#41
  • 1,760 posts
Thanks! I have heard about the brakes etc. Are they covered under warranty? (Not the brakes of course but the other bits)
Yes I would like to see the bleeder valve as that will be swapped.
#42
  • 6,421 posts
Not sure if the bleeder valve is the same on the LR3/4, but it's an easy change for the 3 at least.
I've got new LCA and brakes all the way around from when I bought it at the beginning of the year, but I've already got a small rattle/something a bit loose in the front end. I suspect it may be the sway bar bushings as those are also a known wear item and I don't see them listed in the service records. As for the brakes, even though they are al up to spec I cooked them good coming down Old Priest Grade a couple month ago. And that was with the truck in 2nd/not pushing it at all. Got me wondering about possible upgrades but I haven't looked into it yet.
#43
Hi Chris,
Looking forward to seeing more photos of the new LR4. I am not sure if someone answered your question about the compressor, but Pedram meant that you need to use the bracket supplied by Tactical 4x4 to lift the compressor on 2012+ models. The previous compressor on pre-2012 models was a Hitachi and sat a bit higher. Once they moved to the AMK, it sits quite a bit lower. The good thing is that it seems to be a much more powerful compressor overall. Anyway, if you get the Tactical 4x4 slider you use their supplied bracket to lift the compressor and then you can fit the slider. Pedram and I did it and it wasn't bad at all. I will tell you though that you can hear the compressor running much more - so you will need to add some padding. I hope that helps!
-David
#44
  • 3,890 posts
Haha, awesome!
#45
  • 1,760 posts
So the dealer has called twice to say the truck is ready only to change that to it's not ready on the day we were supposed to go get it. So frustrating, especially since they have our $$ and we don't have our truck. They offered $500 in accessories (BS as we didn't need or want any). Finally after some negotiation to make up for everything they have given us the rear cargo barrier, rear cargo divider, and rear car seats. It helps ease the pain a bit. We have been told Thursday will be the day, we shall see.
#46
  • 3,480 posts
Chris;
Let me know if we need to get out the pitchforks and torches!
-Jared
#47
  • 6,421 posts
I have my printer on speed dial to make a set of giant 'free Chris' truck!' banners that we can then attach to our Rovers while we drive in circles around the dealer's lot.
Just say when.
We've got your back!
If I was cool I'd start a hashtag for you. But I still think it's a pound sign, so I'm not cool like that.
#48
  • 1,281 posts
#freethetruck #we'vegotyourback #doniscool
LMAO!
#49
  • 1,760 posts
I think the dealership is already a little afraid of me so increasing my numbers is awesome. I have already warned them that if the truck isn't ready tomorrow we want them to make the first payment along with all of the accessories etc. We shall see tomorrow.
#notreallysurehowthisworksthisismyfirsthashtagpoundsignpost
Hahahahahahahaha
#50
  • 6,421 posts
Did you mention that you're a surgeon and know not only where all the good drugs are, but where all the not-so-good drug seeking patients who would do anything for a high are?
#51
  • 1,760 posts
May I introduce the newest member of our family!!
[ATTACH]5452[/ATTACH]
Causeway Grey with Black Pack 2
[ATTACH]5453[/ATTACH]
[ATTACH]5454[/ATTACH]
Rox found some instructions and was busy reading them.
#52
Chris..... Tonight....3585 Haven Avenue, Menlo Park
#53
  • 1,760 posts
Yeah not gonna make it. Gotta get the ride set.
#54
  • 1,122 posts
Congrats dude. I know you've been anxiously waiting.
#55
  • 6,421 posts
Looks good!
But I'm a little worried about the child-to-dog size ratio in that last pic. He looks like the freakin' Hound of the Baskervilles!
#56
Congratulations, Chris!
Welcome to the LR4 family, and the even more exclusie LR4 with the black design package family. :-)
Looks so sharp and beautiful. Very nice!
Enjoy and let me know if you have any questions (I loved your post on the LR4 forums - hehe).
Regards, David
#57
  • 3,480 posts
*sigh* putting the pitchfork back in the shed.
Congrats Chris!
-Jared
#58
    NCLR #59
  • 722 posts
  • San Francisco, CA
  • 1995 RR 25th LWB 5.0 TWR
  • 1995 RR LWB
  • 2012 RR A/B Ultimate
Congrats Chris, looks great!
#59
Teds
Teds
    WJ6SPK
  • 908 posts
  • 2001 Range Rover
  • 2009 M1101 trailer
Looks sweet Chris. The black package is stealth. Can't wait to see her.
#60
  • 1,760 posts
Thanks guys! First mod had been done
[ATTACH]5479[/ATTACH]
