ARB Fridge Calibration
9 replies to this topic
Santa, with the help of a holiday sale at 4Wheel Parts, brought me my long awaited ARB fridge! With the voice of Brenton talking about ice cream in the desert in my head and that I can almost taste the properly chilled Pacificos from Ron Boston's generous sponsor I plugged her in to get started.
I have to say, this might have been a "Christmas build" because for the price, my OCD was not impressed with the build quality. Compressor cover panel not fit properly, screw capped not fully seated, even ARB branding not fully stuck I place... Oh well, I fixed all of those.
But the temps looked to be way off... I have an infrared thermometer and a host of other random bits but the only thermometer I trust is in our new kitchen fridge... Anyway - through trial and error and wasted time on hold with ARB, i go to social media. A tweet and a facebook post both get answered, proper phone numbers discovered and I land on the need to "calibrate" the thermostat.
Here is my post over on Expo:
I recently joined the ranks of ARB Fridge Owner and am really looking forward to having it along. Like folks on this thread, I noticed that the temps were off when I first plugged it in.
Here is what I learned:
My Part: Before thinking the temps are way off, there is a right way to measure. Put some items in the fridge and let settle. For me it was two 1 gallon milk jugs 7/8 full of water in each compartment, a couple of aluminum water bottles, a soda can or two, and a few oranges in the upper dairy section. The factory measures the temp in the center of the floor with a static remote thermometer resting on top of/above the internal basket at this center location. After letting the temps settle (overnight) I used both a static and infrared thermometer to test the temp of the water in the jogs/bottles and the temp differential was now in the +/- 10 degree range.
When I finally got through to ARB, a tech (Eric) told me I need to calibrate the thermostat (as suspected) and walked me through the calibration process.
It is as follows:
1) Press and hold BOTH + and - temp setting buttons and HOLD for about 5 secs until AOF appears on the display, then release
2) Using the + or - button, add or remove degrees to the setting. For me I was running warmer so I added (+) degrees to the reading to match the internal temp.
3) After adding degrees, release the button and the fridge will blink to acknowledge/accept the new setting and begin to adjust accordingly
What I learned from Eric is that these fridges are sometimes out of calibration and this is how to do it; there is an 8º range of adjustment (now mine is running at +6 of 8) and calibration has no effect on how cold the fridge will get - meaning it won't now reach a max cold of 6º warmer than a differently calibrated fridge. Also learned the factory temp reading scenario above.
Also of note, the "CH1,2,3,4" settings are for a yet to be released Wireless Monitoring System. If you noticed the small rubber plug on the back by the power connectors, this is part of that. Think of it as ODBII ad there will be a small transmitter that plugs into the rear connector and you can change channels as not to interfere with other fridges within range. There may also be other monitoring type accessories available as well..
I had some assembly QA concerns and he was kind enough to address those apologetically and added "they come from the manufacturer etc.." So I asked who the manufacturer was and he mentioned they are built for ARB by eCamping (?) A quick web search found an eCamping site but
  • 3,418 posts
Excellent post, Tom. I was not aware there is a display calibration function.
Sad that it took going to social media to get a decent response.
looks like you got yanked off stage... bring back Tom!
-Jared
astateofmike
astateofmike
  • 2,236 posts
  • 1988 Range Rover Classic
  • NCLR 004
I have an older model. I bought an internal/external temp gauge for when I use it in the Westy. I know how hot the car is, so I can adjust up or down on the fridge, and I can either montior TOP or bottom temps. Mine only has the C° so it was needed!
I recommend the extra gauge idea.
  • 3,866 posts
Congrats Tom, you'll like the fridge even with the little issues at the beginning of ownership. Good to know about the calibration too!
Original post.
http://expeditionpor...d.php?p=1743561
  • 2,031 posts
It is as follows:
Yes, he told me that too ..... mine still varies temp between unity power and vehicle power, does yours?
Bluetooth, not OBD2. And why isn't this mentioned in the manual? I had the same question.
Think ODB2 as for fridge data. The transport layer is yet to be defined but likely, my guess, it will be a Bluetooth type dongle that attaches to the fridge. Will likely display temp and voltage since the fridge reads both. It has been spoken of in AU but he felt they might be trying to move some additional inventory before announcing... Maybe CES? Dunno but he did feel it would be a separate accessory vs. An app on phone.
  • 2,031 posts
Tom,
Your guess was correct I think, except that it uses "clever wireless transmitting technology" not Bluetooth.
http://store.arbusa....026-P22863.aspx
Edited by GraemeWare, 15 November 2015 - 11:06 AM.
Yup. I had a long chat with those guys.. Interesting platform
  • 6,143 posts
Tom,
You know it's clever - they specifically say so twice!
