New LR4 ladder option?
39 replies to this topic
  • 5,955 posts
Ah, well that's the 64-dollar question isn't it? I don't know either. Possibly you could try a local Autozone-type place and just guess (more than you think is my suggestion...50lbs?) and just test them in the parking lot. Not enough? Exchange it for a stronger one. They often have a lot of them in stock.
*edit*
I have a pair of 12x20 struts laying around left over from some old project. I think they are 60 lb. I replaced one of my hatch struts with one of these (these are a little longer than stock but still fit) and it would hold the hatch up but just barely. I suspect if I were to replace both of them then the hatch wouldn't stay open. I can't cross reference the part number on these but I *think* they are 60 lbs, so you might want to start with 70 or 80 lbs. Oh, I think you want 10mm studs as well.
I'd offer you these, but they wouldn't really help you much.
  • 3,398 posts
I don't see a pressure rating on the struts. Anyone know what I should get?
From my experience on the RRC, I would try a set of stock new upper tailgate struts first... often they are just tired and the new ones should fully support having a ladder added (unless the ladder is made of solid lead.)
-Jared
If you remove the struts and have someone help you because this gets messy by yourself, weight the hatch and give me a roughly estimated guess on what you think it is. I can get you the exact weight and length within a few days. I know a guy. He's in Washington so it's not really far. So length closed and open, and weight is all I need.
  • 5,955 posts
You shouldn't have to go to that much effort. The struts are pretty generic. Like I said, I happened to have a pair laying around that were OK on size, just not strong enough. You can usually pick them up at any auto parts store. Or of course you can order OEM ones from somebody like AB.
  • 3,398 posts
Do be careful of thicker-diameter struts. If I recall correctly the stock ones are already pretty close to touching the frame and going with a larger diameter will probably cause rubbing.
Pedram probably knows a guy though, so everything is good regardless.
-Jared
drafdog
drafdog
  • 138 posts
Oh, Urban Offroad has an even funkier option. I don't know if they actually ever sold one, but apparently he made at least on prototype
I could have used this when our sitter backed into a standpipe on the side of the building, "because the rear backup sound did not tell me to stop?" (face palm!) Lucky for me it center punched the rear window and there was not body damage.
Mark D.
2005 LR3 with a few goodies.
2000 Discovery II - 2" lift, 33"s, steel front winch bumper
(NCLR017)
ROVRMAN2
ROVRMAN2
    NCLR011- Rupert
  • 1,437 posts
  • KJ6IOF
  • 2005 LR3 HSE
  • 2004 DII HSE (deceased)
  • 2003 DII HSE (deceased)
I think there's a video on the AB website on replacing struts.
  • 5,955 posts
Really? They made a video of that? All you need is a small flat-blade screwdriver or something similar to pry the clips loose. Not real hard to figure out even for a first timer. Oh well, I think they also had a video of how to change the air filter. Good for them I guess. At least their trying.
Phil.
Phil.
  • 474 posts
  • KO6RRS
  • 2006 Range Rover Sport
  • 1995 Defender 90 SW
Just curious, what other places have you guys inquired about ladders? Been wanting one since I got my Baja rack, but $700 for the LR one is not my cup of tea. I'm guessing I'll need one custom made for the RRS.
NCLR014
  • 484 posts
Voyager makes one : http://www.voyagerra...ry_iii_lad.html Looks to be a nice piece. They donated one this past year for rover rendezvous. I won one of their Disco 1/2 ladders in the raffle and it matches my Baja Rack better than the stock LR Ladder I had before. I know Baja Rack makes a ladder for Disco 1/2 but doesn't have it listed on their site. Might want to contact them and see if they make one for the LR3/4.
- edit-
Didnt see that you had an RRS. Since this was an LR3/4 ladder thread I only found that one. Not sure who else makes one for the RRS other than the Safety Devices one. Might be able to call Voyager and see if they can make one for you since they can do custom stuff as well..
Edited by psykokid, 09 January 2015 - 04:04 PM.
Derp.. reading fail
  • 5,955 posts
I started to say just get the FrontRunner ladder for $200. Then I caught the part about the RRS. That makes it a little harder. The best I saw in my (short) search was $675 for an OEM one.
  • 3,398 posts
I found the Land Rover Genuine ladder from rimmerbros.co.uk for £370.43/$560.41:
...not sure if the shipping makes it a wash with the prices you can get here. I haven't seen a lot of other options.
-Jared
Edited by RedRover, 09 January 2015 - 06:36 PM.
added link
#33
P-Fab?
#34
  • 3,398 posts
P-Fab?
Certainly another way to go -- that's how I have a super-functional ladder for the RedRover (a '92 RR Classic)... and Pedram has done a lot of work on late model Land Rovers for members in the club as well.
-Jared
#35
ROVRMAN2
ROVRMAN2
    NCLR011- Rupert
  • 1,437 posts
  • KJ6IOF
  • 2005 LR3 HSE
Tom Owen bought parts from Merriam(sp?) out of Kansas City(?) Get hold of Tom and he can tell you.
#36
  • 2,009 posts
I found the Land Rover Genuine ladder... for £370.43/$560.41
GBP374.17 is the U.K. list price, so not much of a bargain.
#37
P-FAB would be the most rugged and awesome, but that guy keeps taking on new orders even when the baby is coming!!!!!!!!!!!!!!!!!!! :-D HAHAHAHA!
#38
*edit*
Hmmm do you have the mounting he as well? I'm working up a project muuhwaahhh!!!
#39
  • 5,955 posts
I don't have the mounting tabs I'm afraid, but you're welcome to them if you can use them. Unfortunately their at home and not in the van so I won't have them at the DitD
#40
no hurry, we can chat at DitD ;-)
Thanks
