LR3 Door Lock\latch Change
2 replies to this topic
Teds
Teds
    WJ6SPK
  • 900 posts
  • 2001 Range Rover
  • 2009 M1101 trailer
I found out the drivers door latch wasn't working properly the other week when I opened the 'locked' door before my wife unlocked the doors. The alarm went off but we could not lock the door from the remote, inside button or manually. It made sounds like the mechanism was working but just didn't work. After searching the web, sounds like this is a common problem with 05 to 07 models especially. Bought a new latch from Rocklin LR and tackled it last night.
Not a technically difficult but a pain in the rear eating to the cable releases. There are good instructions on the web so I won't go over the whole job but I was able to do t without removed the window regulator completely. Be careful not to torque the cable to the inside door latch like I did when removing the latch mechanism.
Check your doors because it could have been broken for months without us knowing.
Phil.
Phil.
  • 475 posts
  • KO6RRS
  • 2006 Range Rover Sport
  • 1995 Defender 90 SW
agreed. had this same issue with my RRS a few years ago. the rear passenger side would unlock from the remote/central locking but it wouldn't lock (though the alarm would arm). however, you could still open the door from the outside. used the online write-ups/youtube videos and it was a pretty easy job. FWIW this is a common problem in BMWs too.
NCLR014
  • 6,091 posts
Thanks for the note - I'll have to check on mine this weekend.  I know last weekend my rear hatch latch started acting a bit sticky at camp and I figured with my luck it would fail completely so I couldn't get to my stuff.  I gave it a quick shot of WD40 and it was OK for the trip, but I'll have to replace it before it does fail.
