Chad's Rover Rehab (and turtle-speed offroad Classic build)
* * * * * 1 votes
121 replies to this topic
  • 1,317 posts
Fair warning to you brave souls willing to follow along: This will be a sloooow build and will be a mix of catch-up maintenance, preventative maintenance, and offroad improvements. Mostly, the purpose of this thread will be to document the tiny things I do and the learnings that come with them, so there will be some minutia that might be left out of other build threads. Also, I'll keep a running list of various maintenance items that need to be addressed.
With that said, here....we....gooooo!
Catching Up To Now
  • January 31, 2015: Stole purchased 1994 Range Rover Classic SWB with 163k miles for the whopping price of $600. Clean title, current registration, all stock, still on air suspension, always Bay Area car. Drove it home.
  • February 28, 2015: Replaced fusible link bundle and a variety of fuses. Celebrated numerous electronics working right again! Replaced several exterior bulbs.
  • March 3, 2015: Removed transfer case shift lock solenoid.
  • March 6, 2015: Removed front air dam and fog lights.
  • March 23, 2015: Wired in 4-flat trailer wiring, splice free! See DIY here: (http://tinyurl.com/qe38tzc) Also drained and filled front diff, discovered axle seal leak into swivel ball.
  • April 6, 2015: Retrieved variety of items from Pick N Pull - various interior trims, latch assemblies, new headliner, etc
High Priority Repairs Needed
  • NCLR Membership (just for you, Tom & Jared) - DONE May 19, 2015
  • Transfer case viscous coupling (failed open)
  • Brake pads
  • Swivel ball seals and axle seals
  • Air conditioning. Undetermined issue, compressor engages fine
  • Air suspension. Clear soft fault and diagnose.
Low Priority Repairs Needed
  • Power steering leak (small)
  • Coolant leak (minimal)
  • Clean and re-seat wheel speed sensors for traction control
  • Adjust and tighten steering box (large dead zone on center)
Preventative Maintenance Planned
  • General fluid refresh- oil, transmission, tcase, diffs, brake, coolant
  • Replace plugs and wires
  • Check engine timing
  • Replace air filter
  • Clear fuel tank vent lines
Interior Repairs & Upgrades Planned
  • Fix drivers door latch difficulties
  • Brace cubby box to support window switch panel
  • Replace passenger seat switch
  • Tighten and Loctite both front seat mounting screws
  • Lube seat rails and sunroof path
  • Retrofit Homelink panel
  • Replace rear wiper switch (and cross fingers rear wiper then works)
  • Replace headliner (already acquired headliner in great shape, need to find fabric for sunroof panel)
  • Replace front right window regulator
  • Replace cabin air filter (does the RRC have one??)
  • Mobile HAM radio and roof rack mounted antenna
Offroad Modifications & Accessories Planned
  • Tires (acquired barely used Cooper Discoverer ATR 245/75/16 Load E on May 8 2015 for $150 for 4. Need 2 additional for spares.)
  • 2" body lift
  • Explore extended bellows for air springs. Or, potential coil conversion if EAS difficulty.
  • Spacers behind bump stops to ensure clearance for larger tires with EAS fully deflated.
  • Rock sliders
  • Diff guards
  • Fuel tank guard
  • Steering component guard
  • Mud flaps F&R
  • Raised intake (planning DIY with 3" exhaust tubing)
  • Breather kit for wading, and confirm all underbody electrical connections well sealed
  • Full length roof rack (planning DIY - thread here:http://tinyurl.com/pl35fqf)
  • LED lights mounted front and rear on roof rack
  • Brush bar if good deal found
  • Limb risers
  • Rear bumper (make TBD) plus custom rear tire carrier
  • Hi-lift jack
  • Shovel
  • Snow chains
  • First Aid Kit
When I bought her:
16825797663_1f751c4e06_z.jpgRRC at Purchase by Chad Thompson, on Flickr
As she sits now (baseline, only visible mod is the front air dam removal) :
17445727511_bcd1c6e39e_z.jpgRRC May 2015 by Chad Thompson, on Flickr
Edited by E36 Phantom, 19 May 2015 - 10:22 AM.
  • 6,091 posts
$600?  Yeah, that was a steal.  Although laying out the full build-list like that is a bit daunting.  It would have been even worse if you put a dollar amount to each, although it would have been interesting to see how much under (because it's always under) the estimates turned out to be in the end.
  • 1,317 posts
Yes, it is a bit daunting, but I want to start with the end in mind. I'm going to log $ amounts as I do things. Since my wife may look at the build thread, I have no interest in putting all the $ values up front for a grand total before this even gets going. :ph34r:
  • 3,863 posts
I stopped updating my list a couple years ago. No big purchases since then.
Hmmm, seems it pastes my spreadshet ok, but when it gets posted the formatting is deleted.
Tires               x3 KM2 255/85/R16   $246.00 4 Wheel Parts   3/17/2013 Lockers               Rear Stage 3 GBR 4.14, Detroit Locker
incl. thrust bolt & 1/2" 20tpi tap   $1,549.95 GBR   3/4/2013   Front Stage 3 GBR 4.14 reverse cut, True Trac locker
incl. thrust bolt & 1/2" 20tpi tap   $1,549.95 GBR   3/4/2013 Fridge/Freezer               ARB 50 qt. 10800472 $799.00 Sierra Expeditions     Snorkel               Mantec Raised Air Intake 110-RAIDS2 $460.00 EE   3/15/2013 Rear Driveshaft               GBR Double Cardon Driveshaft   $424.95 GBR     Gas Tank Guard               CYA Gas Tank Skid   $265.00 RTE 1.866.ROVERTM   Steering Guard               RTE steering guard   $225.00 Lucky 8   9/17/2012 Brakes               Front genuine brake pads   $79.95 Atlantic British   8/29/2012   Rear genuine brake pads   $99.95 Atlantic British   8/29/2012   rear rotors     Will Tillery   9/14/2012 Transfer Case               Seal kit   $39.95 Atlantic British   8/29/2012 Front Axle               Ashcroft HD axles and cv's D2CV $708.00 Lucky8   8/17/2012 Center Console               2004 center console   $65.00 Drillbit, Marty Powell   6/27/2012 Spares               3/4" heim joint for Panhard bar (RH & LH thread) JMX12T $32.00 Filthy Motorsports   9/18/2012   12mm poly bushing for Bilstein shocks (Prothane) 19-920-BL   Prothane   4/22/2012   Gold Seal 1310 U-joint 1310 $19.99 Tom Wood   9/24/2012   Stock driveshaft U Joint Precision 344 $11.99 RockAuto   9/29/2012   Stock driveshaft Center Ball Kit Precision 617 $31.19 RockAuto   9/29/2012   Hose manifold-plenum PEH101540   Eurospare UK Besa 4/10/2012 Throttle Body Heater               Throttle heater plate kit MGM000010K   UROparts Besa 4/10/2012   Throttle body gasket ERR 6623   Land Rover Besa 4/10/2012 Front Driveshaft               Tom Wood's Front Drive Shaft   $389.00 Tom Wood's   4/30/2012 4" Lift               3" RTE rear springs, RR1-3   $200.00 RTE   4/30/2012   3" RTE front springs, RR 4-3 Linear   $100.00 Joe Nosal   1/4/2012   Bilstein 7100 series shocks 12" SB   $450.00 Cambo   8/19/2009   Bilstein 12mm Poly Bushings (Prothane) 19-920-BL $40.00 Off Road Warehouse   9/11/2009   Front lower shock mounts 12mm stud   $45.00 Lucky8   1/3/2012   Front lower spring retainers (bolts M10 1.5 pitch 2.5 inches)   $52.00 RTE   1/10/2012   Extended stainless steel brake lines   $160.00 esteban   1/2/2010   Adjustable panhard bar   $210.00 RTE   3/9/2012   Watts linkage   $345.00 RTE   9/28/2012   Bolts for Watts linkage RND810 $5.95 Rovers North   9/29/2012   Nuts for Watts linkage RND811 $2.95 Rovers North   9/29/2012   Radius arms, lengthened 1-1/8", caster corrected 4.25*   $375.00 RTE   6/18/2012   Trailing arms   $375.00 RTE   9/28/2012   Bolt - Frame M16 x RND783 $15.95 Rovers North   9/29/2012   Bolt - Axle M16 x 100mm RND782 $6.41 Rovers North   9/29/2012   Nut - Nyloc M16 RND776 $2.99 Rovers North   9/29/2012 Spring Retainers               Rear spring retainers EW1 $135.00 EE   10/23/2009 Diff Guards               QT Services Front Defender TD5 A1050 $137.00 Lucky8 716.898.8153 10/10/2008   QT Services Rear D2 A1070 $120.00 Lucky8 716.898.8153 10/23/2009 Radiator               Radiator w/ Secondary Air '01-'04 PCC000710 $319.95 Atlantic British   8/20/2009 Driveshaft Tool               Driveshaft Socket Wrench Tool - 9/16" Nut - 3/8" Square Drive DA1065 $26.95 Atlantic Bristish   8/20/2009 Quick Disconnects               SlickRock Front Quick Disconnects D2DISCONNECT $150.00 Expedition Exchange 310.618.1875 7/29/2009 Rear Driveshaft               Tom Wood's rear drive shaft   $220.00 gmooker used w/ 2k miles no offroad 7/19/2009   4 bolt pinion flange and spacer     PCRover     ABS Extensions               SlickRock Fabrication Disco2 ABS Extension Kit ABS $70.00 RoverDII, DWeb 0309 1140 0001 2548 6088 amicusdiu@yahoo.com 7/27/2009 Spring Seats               D1 rear spring seats   $15.00 Cambo   7/17/2009 Snatch Block               ARB 9000 Snatch Block     winchline.com   6/5/2009 Cargo Door Panel               Aluminum Cargo Door Panel   $75.00 Doug Lawyer   6/2/2009 Tree Strap               3"x10' Am-Steel Blue Tree Strap     winchline.com   6/5/2009 Bumpers               Front slim line full brushbar ($950) License Holder ($25)   $975.00 Rover Tym Engineering 1.866.ROVERTM 3/16/2009   Greg Davis Rear Bumper   $525.00 Greg Davis   6/29/2009 Battery               Sears Die Hard Platinum PM-1 PM-1 $250.00 Sears   3/22/2009   JL Audio 2 AWG Negative Power Wire (3'x $4.50/ft.) XA-BLKPW2 $13.50 Expedition Exchange 310.618.1875 4/16/2009   JL Audio 2 AWG Ring Terminal Set (2x $15) XA-RT-2 $30.00 Expedition Exchange 310.618.1875 4/16/2009 Pelican Cases               Pelican Products 1650 (O.D. Green) 1650NF $180.00 Expedition Exchange 310.618.1875 3/3/2009   Pelican Products 1659 Lid Organizer 1659 $30.00 Expedition Exchange 310.618.1875 3/3/2009   Pelican Products 1560 (Black)   $75.00 Lisa Sheets, craigslist   8/15/2009   Pelican Products 1500 (Yellow)   $90.00 Giovanni 3116 Whitesand Dr San Jose, CA 95148 408.420.7161 3/29/2009 Winch               Warn XD9000i   $777.00 Zach Jaggers DWeb   9/10/2008   Gaskets for planetary gears x2 13848 $0.82 WarnServiceParts.com   11/10/2008   Thrust Bearing (Nylon Thrust Washer) 0 $2.42 WarnServiceParts.com   11/10/2008   Motor cap 61543   WarnServiceParts.com   11/10/2008   Roller Fairlead     Enrique   2/14/2009   Van Beest Green Pin 3/4” Shackle x3 VB34 $90.66 Winchline   2/14/2009   3/8" SKN Gunnebo Sling Hook 0 $46.85 Winchline   2/14/2009   Delrin Rollers     winchline.com   6/5/2009   100' 3/8" Synthetic winch line     winchline.com   6/5/2009 Rear Worklamp               Hella Double Worklamp H15991041 $47.00 Expedition Exchange 310.618.1875 2/10/2009 Binnacle Switches               Front Fog Light Switch YUG102620           Cruise Control Switch x3 YUH100370 $30.00 Will Tillery willtillery@roverguy.com 1/19/2009   Rear Fog Light Switch YUE000290PUY $10.00 Will Tillery willtillery@roverguy.com 1/19/2009   Aux Light Switch x2 STC50098 $30.00 Expedition Exchange 310.618.1875 2/10/2009   Connector Kit For Disco 2 Cruise Control Switch x3 CKD2 $12.00 Expedition Exchange 310.618.1875 2/10/2009   Hella Fused Relay x3 H41510131 $45.00 Expedition Exchange 310.618.1875 2/10/2009 Quick Fists               End of the Road Quick Fist Set (pair) 1" to 2.5" _0010 $10.00 Expedition Exchange 310.618.1875 2/10/2009 Power Inverter               400W Power Inverter PI400AB $49.99 ACE Hardware   2/7/2009 Roof Rack               Safety Devices Tall Highlander Roof Rack RRL156ORA $750.00 Nathaniel, OldscratchGGF 650.346.6265 11/28/2008   PolyMax Non-Overlapping Poultry/Kennel Flooring x4 HA2217 $75.80 FarmTek   12/2/2008   Heavy Duty Cable Ties 17 Inch 175lb (100 pack)   $10.00 BuyCableTies   11/28/2008   Metric socket flat head screw 6mx1.0x40mm x8 6692 $5.76 Bolt Depot   11/28/2008 Dog Guard               Dog Guard STC50082 $115.00 Sue, craigslist flight200@gmail.com 11/14/2008   Mounting kit STC50231 $30.00 Rover Connection 801.942.0030 11/13/2008 Roto-Flex               Roto-Flex rear drive shaft coupler TVF100010 $40.00 Paul O'Shaughnessy (UK 4X4) Dieseldog1@live.com 7/3/2008 ScanGauge               ScanGauge2   $159.99 Amazon   10/16/2008 PCV adapter               PCV hose to intake plenum adapter ERR 6880 $10.99 BMCD 415.776.700 10/13/2008 Battery               Optima Blue Top D34M $160.00 Costco   7/6/2008 Tire Chains               RUD Grip 4x4 Chains #0141   $201.75 Bill Burke 4 Wheeling America 970-858-3468 1/13/2009 Gas Filler Flap Clip               Plastic clip BPX700010 $9.47 BMCD 415.776.700 11/11/2008 HD Steering               HD Drag Link   $100.00 Rover Tracks Keith 303.506.9429     Tie Rod Ends RH & LH   $65.00 Cerrone's 650.365.4145     Tie Rod w/ heims   $144.00 Max Yedor   1/30/2009 Aux Lights               Off Road Light: HID; 7" x2 99000CSK $240.00 Kragen 415.668.5241 7/6/2008 Hub Cap               LR Genuine Hub Cap x4 DTC100810 $80.00 Expedition Exchange 310.618.1875 6/30/2008 Tape               Self Fusing Silicone Tape X10B $9.95 Atlantic British 800.533.2210 ext. 241 Brian 6/17/2008 Air Filter               LR Genuine Paper Air Filter ESR4238 $13.95 Atlantic British 800.533.2210 ext. 241 Brian 6/17/2008 Radio Puller               Radio Removal Tool LRA-76-001ABP $9.95 Atlantic British 800.533.2210 ext. 241 Brian 6/17/2008 Touch-up Paint               AutoSharp Paint Pen- Java Black PP697 $17.95 Atlantic British 800.533.2210 ext. 241 Brian 6/17/2008 Serpentine Belt               Polyvee Serpentine Belt without ACE ERR6898 $31.95 Atlantic British 800.533.2210 ext. 241 Brian 6/17/2008 iPod Adapter               GROM Audio iPod Adapter   $79.99 GROM Audio/ebay eBay 6/10/2008 Air Compressor               Westward Inflator 2AGF1 $98.54 DrillSpot http://www.drillspot.com 6/24/2008 Tire Deflators               Staun Original Tire Deflators (6-30 psi) SCV5 $60.00 Amazon   6/25/2008 Brass Plug               Expeditionware Brass Diff Fill Plug x2 EW32 $40.00 Expedition Exchange 310.618.1875 6/24/2008 Jerry Can               Red Blitz NATO Jerry Can (5 gallon)   $20.00 Joe Nosal "Badfysh"   4/28/2008   CARB conversion kit x2 31710 $30.00 preparedness.com   12/3/2008   Metal Jerry can holders   $20.00 Ron Boston (RonCT110)   11/29/2008   Super Siphon 101 $9.00 Expedition Exchange 310.618.1875 12/5/2008   Super Siphon 6' extension EW29 $4.00 Expedition Exchange 310.618.1875 12/5/2008   NATO Jerry Can Mount x2   $75.00 Expedition Exchange 310.618.1875 1/28/2010   Bundeswehr Gas Jerry Cans x2   $36.00 http://www.deutscheoptik.com/   6/5/2009   Wedco Water Jerry Can   $50.00 Expedition Exchange 310.618.1875 6/9/2009 Wheels               Steel Wheels   $250.00 Joe Nosal "Badfysh"   4/28/2008   LR Genuine Steel Wheel Lug Nut ANR4851 $20.00 Joe Nosal "Badfysh"   4/28/2008 Storage box               Tuffy Box 058-01 $359.95 Morris 4x4 Center       Steel Dividers for Drawer 060-01 $59.95 Morris 4x4 Center     Tool Roll               Bucket Boss Tool Roll 7004 $15.00 Expedition Exchange 310.618.1875 2/27/2008   Bucket Boss Wrench Roll x2 7003 $30.00 Expedition Exchange 310.618.1875 2/27/2008 Recovery Strap               2" x 30' Expeditionware Nylon Recovery Strap EW3 $55.00 Expedition Exchange 310.618.1875 2/27/2008 Tire Repair Kit               Safety Seal Kit SSKAP $50.00 Expedition Exchange 310.618.1875 2/27/2008 Brake Light Switch               Brake Light Switch XKB500120 $14.00 Rover Connection 801.942.0030 2/20/2008   Wiring Harness for Brake Light Switch YMQ503280 $17.00 Rover Connection 801.942.0030 2/20/2008 Locking Lug Nuts               Genuine LR Locking Lug Nuts LRN50300 $115.00 Rover Connection 801.942.0030 9/20/2007 Bodyside Moulding               Bodyside Molding without Chrome Insert STC50061 $160.00 Rover Connection 801.942.0030 9/20/2007 Rear Bumper Lamp               Clear Bumper Lamp RCD2CBL $85.00 Rover Connection 801.942.0030 9/20/2007 Side Marker               Clear Side Marker RCD2CSM $55.00 Rover Connection 801.942.0030 9/20/2007 Steering Damper               OME Steering Damper OMESD02 $69.00 Cerrone's 650.365.4145 1/25/2008 Mass Air Flow               Mass Air Flow Sensor ERR7171 $140.00 Cerrone's 650.365.4145 3/17/2008 Drive Shaft               Re-built front drive shaft w/ Spicer u-joints   $290.00 Cerrone's 650.365.4145 2/3/2008 CDL Linkage               04 Transfer case shifter   $325.00 RoverLandParts 877.443.9246 4/10/2008 Shocks               OME Front/Rear Firm Shocks (used w/ 4800 miles) N107/N108 $190.00 Safari Rover 407.782.7713 Stephen Peter 1/26/2008 Decals               Tailgate "DISCOVERY" mid-silver BTR9896MUKG $20.95 Atlantic British 1.800.533.2210 11/12/2007 Fire Extinguisher               KIDDE dry chemical extinguisher   $15.99 Kragen   2/17/2008 Receiver Shackle               Class III Hitch Receiver Shackle Bracket WARN-29312 $36.54 TruckCustomizers   1/26/2008 Tires               255/85/r16 BFG KM2   $1,004.95 4 Wheel Parts 510.436.4979 12/12/2009   245/75-16 (30.6x9.7) BFGoodrich AT T/A KO x5   $789.90 Big O Tires 415.751.2577 2/24/2008 Sliders               Rock Slider w/ Nerf Bars and Slider Step   $720.00 Rover Tym Engineering 1.866.ROVERTM 3/13/2008 2" Springs               RTE 2" RR4-1 Front Linear/RR1-2 Rear Linear RR4-1/RR1-2 $295.00 Rover Tym Engineering 1.866.ROVERTM 3/2/2008 Cross Bars               LR Genuine Cross Bar Set STC50175 $295.00 Rovers Land 305.754.8800 3/21/2008   LR Genuine Roof Rack Extension Rails STC50034AA $175.00 Rover Connection 801.942.0030 2/24/2008 CB Radio               Cobra 75WXST 40 Channel CB Radio W. Weather 75WXST $97.61 Amazon http://www.amazon.com 4/14/2008   Firestik Cb Antenna Kit - No Ground Plane - w/Mt & Coax FG4-648 $52.95 GI Joes Radio Electronics http://www.gijoesradioelectronics.com 4/13/2008   Firestik Antenna Quick Disconnect K1A $14.99 Amazon http://www.amazon.com 4/11/2008
Edited by Disco2Guy, 09 May 2015 - 11:04 AM.
  • 490 posts
I don't keep track so I can legitimately say I don't know how much I've spent on my truck when my wife asks :) plausible deniability ftw..
  • erinw.rrc likes this
Heard a great joke today about cyclists but it fits here too:
"My greatest fear if I die is that my wife sells my [bike] for what she thinks I paid for it..."
  • RedRover, DHappel and AdvRovr like this
  • 6,091 posts
I've heard that one for lots of things from Motorcycles to sports cars to tools, etc  I'm lucky that Michele has never said anything about my toys.  In fact, sometimes she gets frustrated if I spend too much time trying to find a 'deal' and just tells me to get the blasted thing and be done with it.
  • TomOwen and erinw.rrc like this
  • 2,029 posts
Does she have a sister?
  • 6,091 posts
No sister, and it's best I don't discuss the rest of the family..... :)
  • Justin and erinw.rrc like this
  • 1,317 posts
LMAO. This thread is great.
Brittany doesn't seem to think it's quite as funny as I do, though....
  • Justin likes this
  • 2,029 posts
Chad,
I have been looking into the cristal ball ... I see the future ....
1993-Green-Range-Rover-Classic-on-37inch
  • Justin and AdvRovr like this
  • 6,091 posts
Seems about right.
You're not your own grandpa are you?
https://m.youtube.co...h?v=7AvG6q_iTcA
  • 1,317 posts
That Classic looks like it would have about 10* of articulation with those massive tires.
These are similar to my "crystal ball" dream.
1994_Land_Rover_Range_Rover_Classic_SWB_
  • 6,091 posts
I do have a lot of family from Kentucky...who's to say?
  • 1,317 posts
The cost overruns begin already. Forgot to add lights and herry cans to the to-do list. I think it will be interesting to see how many things I need as I go along that I didn't have on my starting list. I know that there will also be several camping equipment upgrades and storage containers but I'm going to leave those off the tally since they're not really "Rover" parts (which keeps my total lower for the wife. :D )
Also - gas cans. I need some edumacation here. 5Gal Jerry cans seems pretty pricey for what they are. Is there some good reason why not to use something like this, which barely costs more than one Jerry can for 4x the capacity? For $80 for all 4 cans and lids I could have 15 gallons of gas and 5 gallons of water/coolant at the ready with lids that properly seal. http://tinyurl.com/laclble with these lids http://tinyurl.com/omvgxxh There's also this for the jerry can form factor: http://tinyurl.com/ob5xxgm
I know the spouts are garbage but I have good spouts at home, and the HPDE holds up pretty well to the elements in my experience. So, am I missing something important about the jerry cans?
  • 3,863 posts
Bought my Jerry cans right before the "ban" on them. Used the red Blitz cans (w/ stupid CARB nozzle) before that and they leaked all over the truck on my first Mojave Rd. trip. Not the same as what you posted, but the NATO style Jerry can seems to hold the best and never leak (I have a couple extra gaskets just in case). If you've had success with the other types give them a try.
I'd forego spouts all together and use the Super Siphon. No need to lug a full gas can off the roof when you can let gravity do the work for you, plus it's faster. I had a CARB spout on the Blitz cans. The top of the can hit the body of the truck and couldn't get all of the gas out of the can. Oh and they sit taller on the roof as well, where the NATO cans could even be laid on their sides for a super low profile.
Most trips you'll barley need an extra can of fuel. DV or Mojave it's worth having 2-3 for fuel and one for water (with extra water inside the truck/cooler).
+1 on the Super Siphon.  Colin had on Dusy, been hooked ever since...
  • 2,029 posts
.....Most trips you'll barley need an extra can of fuel. DV or Mojave it's worth having 2-3 for fuel and one for water (with extra water inside the truck/cooler).
Brenton,
I hop not.  Maltly they're just for show.  Specifically you can use gravity to empty them, or pour them.  Best to fill them up a head of time (ask Don!).  Sometimes you need to filter the contents.
  • 3,863 posts
Specific gravity? It's hard to see you post. Maybe I need beer goggles AND a beer after reading your post.
