1988 RRC and the EFI Light
- - - - - RRC Range Rover 1988 EFI MAF
7 replies to this topic
astateofmike
astateofmike
  • 2,241 posts
  • 1988 Range Rover Classic
  • NCLR 004
All right, I am having an issue with the RRC.
Check engine light off, the car will buck, almost stall, cough stutter and surge.  It is driveable, but barely.  When the EFI light comes on, the car will idle a bit fast, then settle down and drive.  Gets about 12.5 MPG at 75 MPH freeway at this time.
My first thought was, I have an issue with a sensor/connector somewhere.  As far as I know, 02 sensors are original, MAF is not, etc..and the computer is a later 90's Classic.
And I read on RR.net :  The EFI light is designed to come on when the ECU detects high engine coolant temperature (this uses a different sensor from the one that drives the gauge) or a malfunctioning Throttle Potentiometer, Oxygen Sensor or Air Flow Sensor
SO, great minds, thinking of a 1988 RRC, what sensors are active but would be inactive when the Limp Home Mode kicks in?   If I can figure that out (as it runs fine once the light is on) I can focus on those sensors/connectors first and inspect, clean, and/or replace and test.
Anyone have any idea?
  • 1,321 posts
When does the light come on? Only when driving over 40mph, only once earned up, totally at random, etc? Does the light go back off on its own while driving or only when you turn off the truck?
astateofmike
astateofmike
  • 2,241 posts
  • NCLR 004
Usually at idle.  On Friday, on the freeway and bucking badly, pulled over at a CHP Office and just sat idling...light pings on.  Drives off ok.
This has happened before, but a random time.   It has happened 3 times so far.  Once, car stumbled and light on.  Left it on, it turned off after multiple drive cycles.  Then another time it happened and I had to reset, just a random on.  Then Friday.
I will start with disconnect, clean, grease and reconnect all sensors and start there.  Then see what happens.  But the difference with the light on and no issues...something is being ignored when that light comes on, or the symptoms should continue.
  • 1,321 posts
I don't know specifically on the RRC, but the MAF is common on other vehicles. When they give bad readings things get goofy, and then when they start giving truly implausible readings the system falls back to default fuel mapping and ignores the MAF. It's easy to reach and test. Unplug it and see if it smooths out.
Could also be a small vac leak if its driving well at speed but sputters and tries to die at idle.
Honestly, though, any of the sensors could be causing the trouble. Bad coolant temp readings could make it too rich, O2 readings could go either direction, etc etc.
  • 2,040 posts
Mike,
Can you please disconnect the MAF when the light is off (or reset it) and tell me what it does then?
astateofmike
astateofmike
  • 2,241 posts
  • NCLR 004
Mike,
Can't now, as the truck is at home, but I will try when I get home.
astateofmike
astateofmike
  • 2,241 posts
  • NCLR 004
Mike,
Graeme,
Light off, at idle.  Disconnect MAF.  Truck dies.
astateofmike
astateofmike
  • 2,241 posts
  • NCLR 004
ok, back to my original plan.
Also tagged with one or more of these keywords: RRC, Range Rover, 1988, EFI, MAF
