Lr4 coolant loss
10 replies to this topic
  • 1,186 posts
Today thr idiot light came on. Coolant is def low. Nothing visible underneath. Dont know how long its been low, ive changed the oil but never checked coolant level since buying it.
Do the water pumps have weep holes on them? I just turned 71k miles.
Also what type coolant? Dex cool or some fancy rover stuff? Ok to mix?
William Stephenson
William Stephenson
  • 76 posts
  • San Francisco
  • p38a 4.6
Water pumps are very common on the 5.0 V8. Pull the engine cover and look for orange/pink at the top of your belt tensioner and the pulley should have pink crust on it.
Intake manifolds come off the 5.0 really easy, oil cooler leaks and cross over pipe leaks are somewhat common too, but to examine those I recommend pulling the manifold.
A lot of shops use Dex in their systems, I use OEM rover, sometimes OEM jaguar if I'm out of rover. I don't mess with compatibility on stuff, I can't speak on that behalf.
  • 1,253 posts
Mine has been coming on intermittently for about a week and I finally checked the level today -  it was low, but no leaks anywhere that I could see.  I use Dexcool that doesn't require dilution - already 50/50 blend.
Edited by erinw.rrc, 16 May 2015 - 04:02 PM.
William Stephenson
William Stephenson
  • 76 posts
  • San Francisco
  • p38a 4.6
Floats in the expansion tank do go bad as well causing a false flagging of the error code.
DiscoChef
DiscoChef
  • 1,258 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • '63 109 2A Regular
  • 95 LWB Sold
  • 95 LWB, '67 109
I can attest to that!
Often, it is the sensors that has gone bad and the fluid level is fine. I stick to OEM coolant. LR specific coolant doesn't mix well with others (Ain't that the truth-LOL).
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
1995 LWB RubiconReady, SOLD
1998 D1, 4.6 Relocated to KY
1992 SWB Da Yeti. Dusy Ready
Justin
Justin
    NCLR Marketing Director
  • 552 posts
  • 1991 Range Rover GDE
  • retired-1996 Discovery
  • sold-2001 Range Rover
Pretty sure I can order and have it Monday for you. I'll check on prices. I just woke up and got your text, figured your asleep so I didnt want to reply.
  • 209 posts
I used Pentosin coolant in my rrs - easy to get at Kragen / Winchester / etc. Look at Pentosin web site for compatible version - I think it was Pentosin SF if I recall correctly - pink like the oem stuff ..
PENTOFROST SF (without silicates)
(Formerly LIFETIME ANTIFREEZE G12)
Size: 1.5 liters (1.59 quarts), Part# 8114107
Color: Pink & Clear
CLICK HERE for PENTOFROST SF Spec Sheet
Audi (after 06/1996 up to 2005); Spec. TL 744 F
Jaguar (1997 on)
Land Rover Freelander, Discovery, Defender(1998 on)
Porsche Boxster, 911, Cayman & Cayenne (1996 on)
Saab (2001 on)
Volkswagen (after 06/1996 up to 2005); Spec. TL 744 F
  • 1,186 posts
Vw g12? I have that.
  • 1,186 posts
so i got a new water pump & associated over-priced parts :) today.  started some disassembly to find the leak. well i found it, but not where i was thinking.
looked down in the valley under the intake manifold and i can see a decent amount of coolant there.  if water pump, won't it leak down the front?  the belts are clean, everything on the front of the motor looks clean.  something else perhaps?  i took a pic with my phone and a flashlight looking front the drivers side front corner under the manifold.
Justin
Justin
  • 552 posts
Valley pan gasket could be bad?
William Stephenson
William Stephenson
  • 76 posts
  • San Francisco
  • p38a 4.6
Theres a cross over pipe that leaks as well. They crack at the seem and weep down. The water pump has an outlet in the back to the oil cooler. There are two diamond cut seals, one that contacts the pump and the other one contacts the oil cooler. You can see the water pump diamond seal from the left side (drivers side) of the vehicle. If you know where to look, you can see it perfectly.
5.0 N/A is one of the easiest manifolds to pull ever. Zap all 10mm bolts off and prop up the manifold to get a better visual.
