Its here! With Pics to Prove it!
17 replies to this topic
So i dropped my wife and daughter off at the airport today for a week-long trip to see her family in TN.  Just had a chance to pull the RRC out and start working on it as well as take some pictures.  So here you go.  Big thanks to Dan for everything and for giving it to me before he considered it ready as well as to Pedram for modding the RTE rear bumper on a short timeline.  The maxtrax mount came out great.  I couldn't be happier!
I have several gremlins i'm chasing now which i can hopefully solve this week:
transfer case linkage doesn't seem to want to stay in 4-lo and i can't tell if the diff lock works or not
Bearmach (QTE) engine and transmission mounts vibrate pretty bad
driveshaft issue which i think may be rear pinion-angle related
ham radio install
cut and re-weld roof rack to clearance snorkel.
voyager roof rack is like a HURRICANE above 45MPH.  need to make wind deflector
wire more plugs for the back
QD air fitting on air tank
change fluid in diffs
it has weird road manners if you get on the brakes at highway speeds- it wants to dart left/right (alignment still needs to be checked)
cruise control doesn't work (dan sent me his module to test against)
lotsa little things....
anyone want a wrenching day/night at my place?  have BEER and BBQ..  not planning on working until after Sierra Expedition :)
Edited by ndamico, 03 August 2015 - 06:11 PM.
  • Justin, AA Journey, Teds and 4 others like this
  • 1,339 posts
Whoa. It is actually real! :P
Congrats! She's looking very sharp. Your wind noise is probably coming from the position of your rack, it looks too far back (probably to clear the snorkel?). My Brownchurch surprisingly did not make one single dB increase over the bare roof.
you thin kits worse because its farther back?  i'm cutting it tomorrow and welding in a new piece of tubing to make it sit further forward. never thought having it far back woudl make it louder tho?
  • 3,885 posts
It lives! Looks like the feet of the rack should line up with the door pillars (mainly for strength). I don't know if that will help with the sound issue. Pedram took my rack last week to weld a crack. I don't really notice much of a difference in sound level without the SD rack and 4 lights up front.
  • 956 posts
transfer case linkage doesn't seem to want to stay in 4-lo and i can't tell if the diff lock works or not  (did Dan enlarge the center console wood trim as the LT 230  lever is positioned more to the left ? this could cause it to pop out)
Bearmach (QTE) engine and transmission mounts vibrate pretty bad (what are they made of)  XJS mounts work the best
ham radio install
it has weird road manners if you get on the brakes at highway speeds- it wants to dart left/right (alignment still needs to be checked) could be those skinny 33's or check your tie rod ends better yet replace them...  bad alignment or toe in causes serious death wobble ... is it like that?
cruise control doesn't work (dan sent me his module to test against)  Check all of the vacuum lines from the pedal to the module below the left headlight and the bellows on the throttle.  Does the switch on the console light up?
  • 956 posts
After looking @ your pics I would try a different steering damper?  those Bilstein dampers always tend to push your steering to the right .... if you want the look and a better  functioning damper Fox make a nice one!  it may need rebuilding a few times but @ least you didn't buy their Shocks ( smart move)
Looks like the Cruise has been relocated too
Try to keep the weight low down (center of gravity)  RRC's are still way better than Disco's @ this though. :P
Nice rig but we need to see some scrapes on it or we may put you in the Poseur class :D
  • 1,339 posts
Can't say for certain, too many variables. But, the little Thule crossbars on mine did make some noise and the front one was roughly centered over the sunroof. I took them off and it went away completely. I put on the Brownchurch and didn't hear any difference in noise at all.
It could be that the leading edge is farther forward and I think it's certainly possible. But it could also be the lights up top, or that it has upper and lower bars, or the flooring. Unfortunately it all went on at once so I don't have solid data.
At any rate, it does look too far back, and Voyager is not a cheap off-brand so i would imagine they would've minimized noise. I think it may be worth seeing what would happen when it's in the right place before you go chasing fairings and other things.
  • 6,314 posts
Looking good.  Too good - now you're going to be scared to scratch it up in the rocks!
    NCLR #59
  • 722 posts
  • San Francisco, CA
  • 1995 RR 25th LWB 5.0 TWR
  • 1995 RR LWB
  • 2012 RR A/B Ultimate
Looks great - turned out really well!
The engine mounts are solid metal (I think) so would think you'd get more vibration out of them.  With the Voyager rack, I've heard a couple of similar stories about the noise - just need to build a good wind deflector for it.  On the darting left or right under braking, could it be the bushings?  Had that issue on mine and replacing those fixed it.
  • 6,314 posts
Diagnosing the issues is much harder since you didn't have the truck before all the mods.  No base-line to work from.  And since everything went on at once it's doubly tough.  Wish I had more to offer other than sympathy but I'm no RRC expert.  I might be able to help with that wrenching day though.
Got the rack cut and re-welded.  not one of my best jobs but its done and it doesn't hit the snorkel anymore.
AlysonH
AlysonH
  • 839 posts
  • KJ6MIO
  • 2003 DII (weekend)
  • 2012 Range Rover (work)
Nice rig!
I'm curious if you happened to have an old Reagan sticker sitting around or did it come with the truck?
  • 6,314 posts
I'm scared to do a search, but I'm going to guess you can probably find something like that on ebay.
Instead of pranking Nick with the cowboy butts license plate frame, we'll have to take a page from Top Gear and put a Hillary '16 sticker on his rig.  :)
Welcome to the Poser class ;-)
I bought that sticker new this year. thanks for noticing :)
Nice rig!
Yes Don, that would be a good prank..lol
It looks great. I love it.
Sent from my VS985 4G using Tapatalk
Teds
Teds
    WJ6SPK
  • 904 posts
  • 2001 Range Rover
  • 2009 M1101 trailer
Great looking rig! Now to get her dirty...
When I put up my long curved LED light bar, it really helped with wind noise. I mounted it close to the windshield and it is really bright as well! A 50 inch one would cover the whole rack.
BEAR
BEAR
  • 701 posts
  • Concord
Nick I love the look. The rack looks great and that rear tire carrier w/ jerry can holder and maxtrax looks awesome. I really like the supple yet inspiring IPA on the hood.
  • ndamico likes this
Concord CA,
2006 LR3 SE with HD
"waiting for an adventure"
