High temperatures on the DII... Bad thermostat?
5 replies to this topic
I noticed my factory gauge start to climb towards the read as I was driving on the highway at 55mph. The outdoor temperature was 116°F, so I did t think too much of it, I just turned on the heat, and the gauge returned to normal rather quickly. Today I was cruising at the speed limit of 75 when it was 101°F, and my water temperature went up to 231(measured on the new Scanguage). That seems quite high to me. I have noticed a pinhole leak in my lower radiator hose, so would it be worth doing the thermostat with the hoses? Around town the water temperature stuck to around 215°F.
Thanks,
lutz
lutz
    NCLR053/SCLR
  • 684 posts
  • Grover Beach CA
  • KK6QGU
  • 2004 Discovery 2
  • 1999 Discovery 2
  • 2008 LR3
if your going to do it put a 180 degrees thermostat. Btw have a good time in college
Edited by lutz, 15 August 2015 - 07:18 PM.
KK6QGU
99 Discovery 2 -Parts truck
2008 lr3
Thanks! I'm not sure if it has one in it already, but I'm pretty sure it doesn't. It just strikes we as odd that it is warmer on the freeway than idling around town.
I sprayed out the radiator a little bit, and it was sitting around 225instead of the 232 yesterday. Exact same drive, still 101°F out. Based upon the fact that it's cooler around town, I don't think it's the thermostat. I guess it's time to pull the rad out for a cleaning, and do a chemical flush along with the all the hoses. We'll see what it does them.
  • 2,049 posts
Tyler,
Cow Mountain dust ... good for at least 10 degrees on Katrina .... I couldn't even see the radiator fins .... that'll happen when you run 30 miles or so at high speed tailgating another vehicle.
willie101abn502
willie101abn502
    Beginner
  • Pip
  • 3 posts
Use the thermostat for a d2 diesel, lower temperature for summer, not good for winter
Sent from my XT910 using Tapatalk
