95 rrc high output alternator
11 replies to this topic
  • 1,174 posts
Im thinking my stock alternator is insufficient to charge my dual agm's. Also wondering if the voltage regulator may be too low and not ideal for them. Has anhone changed to something better?
    NCLR #59
  • 722 posts
  • San Francisco, CA
  • 1995 RR 25th LWB 5.0 TWR
  • 1995 RR LWB
  • 2012 RR A/B Ultimate
Think I swapped to a higher output (120amp) Bosch alternator for my dual batteries.  It's been a couple of years since I did the switch but it happily charges my batteries
  • 5,963 posts
With AGMs you might indeed be able to use a higher charging voltage, but you would need to go to an adjustable regulator. They can probably take a faster charge via higher current as well. Unfortunately I don't know what the hot ticket is for an RRC.
  • 1,174 posts
Any info on where you got it, etc? Part number just maybe?
  • 1,174 posts
back to this. i can tell my alternator is not putting out enough juice.  does anyone know if a P38 alternator will bolt up to a 95 RRC?  the electrical part i can adapt. just trying to find something that will bolt up.
DiscoChef
DiscoChef
  • 1,250 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • '63 109 2A Regular
  • 95 LWB Sold
  • 95 LWB, '67 109
I don't know about a P38 but I know that D1s, RRCs and maybe DII are interchangeable. I don't see why it wouldn't work on a P38.  Antonio, Rob or Ted ay be abe to give you the right answer. Good luck!
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
1995 LWB RubiconReady, SOLD
1998 D1, 4.6 Relocated to KY
1992 SWB Da Yeti. Dusy Ready
  • 1,174 posts
i am thinking of trying the CS130 delco alternator as an option too. i have read that one from a saturn will fit too.
  • 1,174 posts
mean green has one.  i'm getting more info on it.  has anyone tried one of their units?  they claim 200A.  stock pully, not overdriven.
  • 5,963 posts
That's a lot 'o amps you're talking there.  I'm not familiar with their unit, but that's about as big as anything I can think of.  I would think they'd need a larger case to handle the heat.  Maybe a remote mount regulator as well, which wouldn't be a bad thing if it was also adjustable.
fwiw Balmar is usually the first place I look when hunting aftermarket alternators, but mostly that's because they offer ignition protected marine stuff.  They also have standard automotive gear as well, though I have no idea how they stack up on pricing.  The marine stuff is brutal....4-figures for an alternator.
Edited by DHappel, 29 November 2015 - 01:17 PM.
  • 5,963 posts
One other concern is belt slippage if they are using the stock pully.  Usually something that big needs dual belts or a big serpentine just for enough drive friction.
  • 1,174 posts
ok, so got one on and running.  talked to Premier power welder in socal.  i have a denso unit with an external regulator.  it sits a little higher so i had to cut the fan shroud. also the pulley is smaller so i need to correct my tach signal.
Edited by ndamico, 09 December 2015 - 01:25 AM.
  • 5,963 posts
I like the remote regulator.  Should run cooler and it can be replaced easily if it fails.  Is it also adjustable?  It would be nice if you could fine-tune it to your choice of battery.
