LR3/LR4 Parts Source Suggested/Replacement Parts Thread
64 replies to this topic
  • 2,045 posts
sounds good. put me in for one of each in the bearmach variety.
Added to order.
  • 6,160 posts
Unlikely you'll get stronger ones in the same form factor.  Typically they will get fatter, which you may be able to use by adding packing under the mounts (but I've never tried it, so that is only a guess).
Actually I'd bet you can get them.  I can get gas struts in many sizes.  I just spec out the compressed x extended length, end fitting type and stud size, and lb-rating.  Not every possible combination is available, but most are.
The hard part is figuring out how strong the stock part is.  Once we know that you can figure out how much stronger you want and I can probably track it down for you.  I haven't looked at my own struts - sometimes they are marked on the body with a weight rating but I wouldn't count on it for an OEM part.
If somebody wanted to experiment it shouldn't be hard to figure out all the specs other than weight rating; we could then take a guess and try a couple different parts. I should be able to return the unused ones at no cost.
  • 6,160 posts
OK, I got curious enough to go out and look at my truck.
Without removing a strut to measure it, it's about 11" compressed x 19" extended.  The only rating I can see is 480N - 480 Newtons?  I'd have to google up how to translate that to lbs.
Looking at a catalog the closest thing I see is 10.2"x17.2", or 12"x20".  A little over on the extended length is fine but I don't know if there's room to go 12" compressed.  They are available in ratings from 20 lbs to 120 lbs.  As an example, a 10.2" x 17.2" 60 lb would be about $20.  It would have an 8mm rod and fit 10mm studs.
We'd have to do some more checking, but that's getting close.
  • RON CT110 likes this
  • 6,160 posts
Google tells me 480 Newtons is 108 lbs of force.
Checking my catalog, I have 110 and 120 lbs in 12x20.  The stock strut is about 11x19, but again we aren't too worried about not using the full travel.  And it appears when fully closed, there is still about 2.5" of shaft extended out of the stocker, so the 12" compressed length should work.  I'd have to actually pull one off and check the size of the studs used, but 10mm is very common so I bet that's what they are.  Again, you're looking at about $20 per strut.
  • 2,045 posts
 Will wait for the next shipment; put me in for a pair; what's the eta of the next shipment.
Ron,
Shipment just cleared customs.  The item is now on the website, and if you choose "delivery at an event" there will be no shipping charge.  Then we just have to work out what event ....
  • 2,045 posts
Phil,
  • 2,045 posts
Enrique,
Just added two more to the order I have going in later this week.
For the rear I see part number BHE780060 listed and I can only get those in genuine LR parts at a whopping $60 each.  I expect they are cheaper from other vendors.
There is a TSB (Technical Service Bulletin) number LA501-018 that affects older vehicles.  The mount on the body loosens in the nut, the nut breaks loose, then the strut falls off.  The stealer then has to drill a hole to get a new nut into position.  Suggest everyone checks both left and right are tight.  Many may have had the recall, but not all.
Enrique,
  • DiscoChef likes this
  • 4,775 posts
Ron,
Ok went to http://www.roverware.us/ and then check-out via Paypal showing the balance to be paid. I clicked continue.  Then took me to RoverWare secure check-out screen.  I don't see "Delivery at an Event" as an option.
I will come back to it later - maybe I am overlooking it.  Thanks! I'll figure it out.
I'll pay for it now and then we can figure out which event.
Thinking the Catahoula Coffee get together/swap meet on Dec 20th.  Are you planning to attend?
Edited by RON CT110, 26 November 2015 - 09:48 AM.
yarrover
yarrover
    NCLR Club Memeber
  • 315 posts
  • 2006 LR3 HSE
Hi Graeme,
I just realized this morning i need the hood struts for my LR3 as well. Do you have them in stock or need to order then order one for me with your next shipment.
Let me know.
Damn looks like a season of hood struts replacement  :D .
Thanks
Anudeep
Anudeep (YARRover)
with HD Package, BFG KO2's !!
  • 2,045 posts
Anudeep,
We have them in stock.  Good job I purchased extras for stock.  They are now on the website (just Google "RoverWare" and we should be the first hit).
  • yarrover likes this
  • 2,045 posts
All,
And at the request of another member, we now stock a kit of front differential bearings/seals for LR3/LR4/RRS.  It seems that the idea of just supplying parts for solid axle Rovers went a little sideways, but we want to stock what you guys need!
  • DiscoDavis likes this
Phil.
Phil.
  • 478 posts
  • KO6RRS
  • 2006 Range Rover Sport
  • 1995 Defender 90 SW
Phil,
thanks, graeme. just completed the checkout and chose delivery at an event. not in a rush so we can figure it out.
NCLR014
#33
Phil.
Phil.
  • 478 posts
  • KO6RRS
i had troubles adding anything to the cart using safari on OS X. i switched to chrome, chose paypal checkout and was able to proceed normally. i found delivery at an event under the shipping methods.
Edited by Phil., 01 December 2015 - 01:28 PM.
NCLR014
#34
yarrover
yarrover
    NCLR Club Memeber
  • 315 posts
  • 2006 LR3 HSE
Anudeep,
Thanks Graeme.
If you are driving by east bay and driving by the restaurant please drop them at the restaurant. If not will pick some other event so that i can collect them from you to avoid shipping costs.
Also let me know the payment type, if you want i can give you cash when we meet or you drop it at the restaurant. or paypal.
Thanks
Anudeep
Edited by yarrover, 01 December 2015 - 03:54 PM.
Anudeep (YARRover)
#35
  • 346 posts
All,
Wooo thanks Graeme!
This may be the way to go as the D3's and 4's get older. LRNA continues to insist on a full swap of the core at several thousand dollars whereas more and more stories pop up of people confirming it was only one or two bearings gone bad, no need in a few cases to go beyond just splitting the diff open and using a bearing puller on those main bearings (apparently defender wheel bearings... go figure!), slap that thing back together and BAM, more $$$ for goodies.   :lol:
Edited by DiscoDavis, 01 December 2015 - 05:12 PM.
  • DHappel likes this
#36
  • 2,045 posts
Phil,
Thanks, and double thanks for the feedback.  One of the benefits we get from NCLR is that we get this sort of feedback.  If this happened to a 'random' customer, we may have lost a sale.  I logged a case with our host, and will see what they say.
We won't be at the MORG this month, but will be at the DitD (Peninsula Chapter), and should be at Catahoula on Dec. 20, 2015 too.
Edited by GraemeWare, 04 December 2015 - 06:36 PM.
#37
  • 2,045 posts
Thanks Graeme.
Thanks
Anudeep
Anudeep,
Can't be certain, but might see you next Tuesday lunchtime.
#38
  • 2,045 posts
Ron,
Yes, we're planing on Catahoula.  May even have an old friend with us .... Christmas surprise .....
I'd be interested to see what happens when you continue on using that Paypal link.  Using the normal check-out you can also select Paypal, but with the quick link it should work too (I couldn't test that in the non-production environment, since Paypal didn't support it).   Amazing how much you learn when setting up e-Commerce .... things that I'd prefer never to have had to learn ....
#39
  • 6,160 posts
And somehow my hood struts just decided to fail today.  Weird...no problems at sunday night and today the hood does't even try to stay open.
#40
  • 2,045 posts
Ron,
Ron,
I checked, and the option comes after PayPal sends you back to the site ...
