Double Cardon Driveshaft?
25 replies to this topic
  • 1,317 posts
The previous owner lifted my P38 appx 4" and left it on the stock driveshafts. They are quiet and fairly smooth when they're under accel or decel. But, any time they're in float above, say, 35 MPH they buzz whine quite a bit.
He said it didn't bother him enough to change them over, but I'm pretty nervous the UJs are going to decide not to put up with that torture for much longer.
Is that a valid concern? If so, is a double cardon the way to go, or should I look into other options?
Thanks
  • 6,093 posts
That seems odd- you get it only under float?  And you're sure it's the driveshaft(s)?
I don't have any answers since I'm not a solid axle guy (though I will be watching for future information).
My gut says if they've lasted this long and been OK I'd be tempted to just put in new U-joints and go for it.  Front shaft U-joint failures on Discos are certainly well-known so maybe you just picked the truck up on the tail-end of the service life and you'll be fine.  I'm not sure what U-joints sell for but I think a Tom Woods shaft is $3-400 so certainly they would be cheaper than that.
  • 1,317 posts
Say what? Not a solid axle guy? You've got two Rovers with solid axles and only one with independent.
No, I'm not completely sure, but it's unlike other drivetrain noises I've heard in the past, the seller believed it was DS, and it is lifted quite a bit. The guy owned this thing for 10 years and has had it built for a large portion of that. However, he did more slow speed crawling while I'll probably do more medium-duty exploration style stuff.
Volkov
Volkov
  • 226 posts
  • Vallejo
  • KK6UUO
  • 1977 Land Rover 101FC
Try to find a protractor and measure the angle of the driveshaft. 20 degrees is the maximum angle you can have for a shaft.
Volkov
Volkov
  • 226 posts
  • Vallejo
  • KK6UUO
http://www.pirate4x4...fe vs angle.jpg
Here is a chart of driveshaft angle versus life expectancy
Edited by Volkov, 21 December 2015 - 09:40 PM.
  • 2,029 posts
Chad,
Noise on float is quite normal when running at extended angles.  I'm running Gwyn Lewis shafts (the ones we stock) which are 35 degree single cardon, on Katrina, and have the same issue if I want to .... by which I mean that I keep them slightly loaded to avoid that frequency of oscillation.  The clocking of the shaft ensures 5/7th harmonic cancellation for most of the time.  We do not recommend double cardon as that is added rotational mass and adds more problems than it solves.  Ever heard of a D1 or RRC smashing a gearbox when a shaft fails?  I haven't, and have had one fail myself.  I do know three people that have had a D2 demolish their gearbox on failure.  Grease every 250 miles (but don't worry if that becomes 500 on a long journey) and after wading, then you're golden.  Yes, there will be someone that contradicts this, but driveshafts will always fail, so ....
  • 6,093 posts
Chad,
I was waiting on this - I was pretty sure I knew the Ware Theory on Driveshaft Joints.
  • 6,093 posts
Forbidden - you don't have permission to access...
Edited by DHappel, 22 December 2015 - 07:04 AM.
Volkov
Volkov
  • 226 posts
  • Vallejo
  • KK6UUO
  • 3,863 posts
Sorry Drew, still no love...
  • 6,093 posts
I'm not even that interested in the chart, I really only want to see it because I can't.
Volkov
Volkov
  • 226 posts
  • Vallejo
  • KK6UUO
Hopefully the third time is the charm
  • 2,029 posts
Drew,
I would challenge the data for that graph. The concave shape makes no sense.  Extrapolating off the end you could keep increasing angle and not affect joint life at all.  As the angle increases, wear must increase exponentially, not reduce exponentially.
Edited by GraemeWare, 25 December 2015 - 11:05 AM.
robg
robg
  • 216 posts
Both Ted and I switched to DC's from Tom Woods as we both run lifted P38's - Made a world of difference.
Make sure you lube them according to Wood's directions before installation.
Side but related question, have you modified your Panhard rods? If not I suggest doing this next.
LUCAS - Loose Unsoldered Connections and Splices
My TW only lasted two months before the centering ball failed. They are rebuilding it for free, but still that's not great. Just something to take into account...
  • 1,103 posts
Mr Woods drive shafts aren't the only game in town. If you're near west sacramento drive line services will make whatever you want for a reasonable price. Just sayin.
  • 1,183 posts
That place does nice work indeed.
Sent from my SM-T807V using Tapatalk
  • 1,317 posts
Graeme, trying to distill your post. Is your dislike of DCs due to:
1) the extra weight making DC joints more prone to failure, or
2) the quality of workmanship/parts on DC joints available for Rovers making these DC joints more prone to failure, or
3) the extra weight making catastrophic damage more likely in the event of failure?
DCs are run from the factory on some vehicles so it seems like there must be a way to make them reasonably reliable? Greasing every 250 miles seems very excessive. And, would a DC really be less reliable than a standard joint bring run well beyond its max angles?
I'll check out Drive Line Services. I also saw a place on yelp in San Jose, I think it was South Bay Drive Line, that has great reviews. Probably will talk to both and see who I like best.
  • 1,183 posts
check out the yelp reviews for driveline service in west sac.  they rebalanced my GBR shaft.
  • 2,029 posts
Chad,
All of the above, in the order 1, 3, 2.  And also they are not necessary for the majority of Rover builds.  A double cardon naturally has greater play due to the centering arrangement to ensure that both joints move equally.  Some don't have a grease point for that center ball, and those that do are really hard to ensure grease actually gets in there.  Once that wears, the whole thing is out of balance, and basically shakes itself apart with high frequency vibration (the two out-of-phase joints cause higher harmonics).  If you measure what you need for almost any Rover, it is way within what a single joint can do.  You never get to the 25 degrees that a standard single joint can do, and with 30 degree GKN "ultra" joints can allow, double joints are unnecessary.  Personally. I like the GKN joints and will pay extra for them.  Never had one fail that wasn't abused.  "Abused?"  Yes, 40,000 miles of road and wheeling, without greasing, on a 2" lifted Classic.  I recently threw away the evidence (the spider looked like it had been welded it had got so hot).
250 mile greasing interval might be excessive, but 250 becomes 500, becomes 1000 .... and then the next thing you know things go bang.  We're lucky in California that we don't have water and salt, but for 5 minutes under a vehicle, I'll er on the side of caution.  Changing a gearbox is the worst job on a Rover, in my opinion.
DCs are rarely fitted on standard vehicles for flex reasons, it is for vibration reasons.  This is why the D2 has one and the D1/RRC/Defender doesn't.  By clocking the UJs most harmonics can be designed out, and adding weight to stop pinion vibration can help too (but how many of us still have those fitted?).
South Bay Driveline are great, if you catch them on a good day.  Steve knows what he is doing, but their prices are usually rather high.
A good driveshaft is usually painted blue (!!!).  Not all drivelines are built equally.
Note in this picture the position of the involute splines.  Far better when off-roading.
Involute_Spline_110mm_1__54496.143337461
Edited by GraemeWare, 26 December 2015 - 10:20 AM.
