Rear Working Lights for DII?
- - - - - Lights
15 replies to this topic
cjohanson
cjohanson
  • 36 posts
  • San Francisco
  • 2002 Discovery II
  • Someday - '67 IIA 88
I want to install some rear working lights on my 2002 DII.  Anyone done this and have some pointers / ideas?  I found this thread and am going to try to do something similar to the Grey Disco with the Hella FF worklight pictured.
https://www.landyzon...g-holes.145899/
Thanks!
Chris Johanson
cjohanson1234@yahoo.com
  • 1,090 posts
mine are on the rack but if you dont have a rack then a gutter mount would work great.  Best of luck.
  • 5,951 posts
I mounted a small LED bar on the back of my rack, but I can see how the gutter mount would work easily enough on a D2.
That gutter mounts looks cool, I've seen similar antenna munts that may work as well...
As for lights themselves, I think you are smart to consider some of the current LED options, the lumen output to power consumption ratio is well in our favor now vs. the Halogen of yesteryear. ;-)
I have a set of these facing aft and another pair off to the sides but as Jason pointed out, they are mounted under my SD rack...
For your application (sans rack) a couple of members run something similar to these and they seem to throw out a lot of light.
Wiring is pretty straight forward. If you haven't pulled a dedicated circuit to the rear yet, it may be a good time to do it although you may be able to get away with 1 lamp off of the trailer harness if that's your plan. If not, I'm sure you'll find more uses for the dedicated circuit like, say, the fridge.. (in which case, plan for this with gauge and fuses in the beginning ;-)
Hope this helps,
Tom
  • 3,856 posts
Hey Chris, I have an old Hella dual halogen work lamp you can use if you want. Worked fine when removed from the truck (went LED). Good for mockup purposes as the bracket (as I remember) uses the same sized bolt.
The real question is how/where you want want to run the wires for power, and the switch to turn it off/on. I use the empty binnacle switches on the left of the steering wheel for the work lamp, inner and outer roof rack lights. For a factory look and finish, you can use cruise control switches and swap the cover to suit your needs. Though they will be mirrored. Expedition Exchange carries the multiplug connector that fits the c/c switch.
Desertcrawler
Desertcrawler
    Chuck (NCLR025)
  • 1,776 posts
  • KI6WSR
Worth thinking about how you want switches to work. I put my switch in the front -- and it allows them to work as backup lights (turn on automatically) or be constant on.  Sometimes nice to run them constant on when in high dust situations and you have someone following you (like a road rally race).
But you should get a rack. Every D2 needs one. It saved mine from being crushed by a tree.
Chuck (KI6WSR)
3" RTE Lift,Bilstein Shocks, GBR 4:11s gears, Rovertym bumpers front & rear, 2 IPF HID lights , rear work lights, custom sliders, diff guards, gas tank protector. Warn 9600 winch, synthetic rope, 285/75/16 tyres, Brownchurch rack, CDL Linkage, Heavy duty drive shafts, ARB air lockers, heavy duty rear axles & front CV joints from GBR. Ham & CB radio
  • 3,856 posts
First pic is the wiring diagram I used. It's good for any 2 wire lighting setup.
Second pic are some switch options. The cruise control switch (far right) is the only factory option you can use (click on, click off), but you can pick and choose the covers for the most part. Find a pick and pull for these.
Third pic is everything wired up with the light on. Bonus for the illuminated switch, which doesn't really matter. The steering wheel covers up all of those switches on that side anyways...
9.16 Amps, we can see why you went LED ;-)
cjohanson
cjohanson
  • 36 posts
  • San Francisco
  • 2002 Discovery II
Thanks for all the great advice!
Chris Johanson
Any updates?
cjohanson
cjohanson
  • 36 posts
  • San Francisco
  • 2002 Discovery II
Haven't had time to get it wired up but I have the lights, mounts, and the switches, I just need to make sure to get the right relays.  There are a few other projects in mid-stream too!
Chris Johanson
  • 3,398 posts
Sounds like it's time for another Wrenching day... Who's hosting? I'd do it but we have a big porta-potty in our driveway... No garage access due to home remodeling.
There's a fix for that...
Edited by Pedram, 26 May 2016 - 03:10 PM.
I know a guy.... I have a few relays here. With plugs. You just need to run longer wires and hook up the rest yourself. Or just come over and I'll help you. Got everything here at the house.
AlysonH
AlysonH
    NCLR Secretary
  • 817 posts
  • KJ6MIO
  • 2003 DII (weekend)
  • 2012 Range Rover (work)
Did you ever figure out the LED lights for the yellow lights on the back of the disco? You mentioned trying to find one that flashed correctly.
Why yes, I have adjustable relays for LED turn signals. But I have yet to install it on my disco. It's parked at a shop currently. But I'll do it when I get it back. I have used a different style years ago before my wheeling days and did the install myself. It worked great. I'm pretty sure this is similar.
