RRC Catalytic converter pipe cracked
7 replies to this topic
Dino
Dino
  • 89 posts
Pipe is cracked about 2" below the manifold connection. The cat system from Rovers North is not the genuine part and "cannot" be used in California Has anyone repaired/welded one of these? any help would be appreciated.
Thanks, Dino
94' RRC LWB
Justin
Justin
    NCLR Marketing Director
  • 553 posts
  • 1991 Range Rover GDE
  • retired-1996 Discovery
  • sold-2001 Range Rover
Cough cough, I could provide one with the sale of some "Bolts"
Mind sending me a PM of yours?
You may be able to get it welded if the crack is where I am picturing. Could you post pics?
Timbo
Timbo
  • 150 posts
  • El Dorado Hills, CA
  • 1994 Range Rover LWB
If it's the exaust itself then yes should be mild steel so I would think you can get welded - if you can get access.
I had a hole just before one of the Oxy sensors, that was fooling the sensor and causing the engine to run Rich and fail smog. Welded up no problem, and car them passed.
Dino
Dino
  • 89 posts
I think Ill pull it down and try to weld it....... thanks for the help gents.
94' RRC LWB
  • 1,122 posts
Mine broke off in the same location one day.  It could have been welded.  I wonder why there is increased stress in that location.  Was yours on the passenger side?
Dino
Dino
  • 89 posts
JFuller - yes passenger side. Looks like the weld should be the fix. New cats we can't use in Cali are 700.00 bux!! :huh:
94' RRC LWB
TigerDan
TigerDan
  • 945 posts
  • North of the North Bay
  • KO1RVR
  • 1991 Range Rover
  • 1995 Defender 90
  • 1961 Series 2 88"
  • 1994 RRC SWB
  • 1994 RRC LWB
I've welded several with no problem. I welded the one on mine in about the same place when I first got the truck almost 10 years ago and it's still going strong.
NCLR087
