Where to adjust the emergency brake tension
8 replies to this topic
DiscoBears
DiscoBears
  • 99 posts
  • 1998 Discovery LSE
Does anyone know where to ajust the emergency brake tension...the light stays on and it dawned on me the lift would creat tension how have you all dealt with this?
Sent from my SCH-I535 using Tapatalk
Tension, or adjustment on the shoes is a 17mm nut on the drum off the transfer case. Not sure that is what pulls the handle down to press against the switch or not...
Good luck,
Tom
  • DiscoBears likes this
By the way, you can download the factory service manual from here. http://www.landroverresource.com
It's a lifesaver for things like this, and you don't have to wait for us to reply. :)
As far as the e-brake light, I don't think it's related to the tension in the cable. You probably have an electrical fault somewhere. Probably a failed switch.
Edit: at least on a DII, it could also mean low fluid in the brake reservoir. That's a simple thing that may be worth checking as well.
Edited by lilcrawler, 23 March 2016 - 10:23 AM.
  • 1,106 posts
The lift wont affect your e-brake tension since it's attached to the t-case and you did a spring lift so the distance didn't change.  If I remember correctly there is a switch in the center console under the e brake handle that has likely come off it's mounting position and is responsible for the extinguishing of the dash light.  If you e-brake needs loosening or tightening you can follow Tom's advice above.  You will need to adjust tension of the e-brake cable if the e-brake no longer holds the vehicle when applied or if for some reason the cable had been over tightened and now the e brake can not be released.
DiscoBears
DiscoBears
  • 99 posts
I read the rave more than I read fiction these days...lol...but I really look forward to the feedback it reminds me I am not a special snowflake and that there probably is a simple answer someone here has already experienced...
  • Justin and Jethro like this
Amen  Snowflake  :-)
DiscoBears
DiscoBears
  • 99 posts
Nice catch it was the reservoir thanks again...
Ah. Cool. I was wondering what it was. Glad everything worked out. :)
DiscoBears
DiscoBears
  • 99 posts
I do the single person blake bleeding trick it hasnt failed me yet but sometimes it drops the reservoir. I forgot to check after driving it...thanks again....
