Something is catching when I turn...not the fender
9 replies to this topic
DiscoBears
DiscoBears
  • 99 posts
  • 1998 Discovery LSE
So something is rubbing when I do deep turns I will have the wife drive it later so I can watch but I can confirm it is not fender realted...sonething internal maybe...anu thoughts or places to look?
Sent from my SCH-I535 using Tapatalk
  • DiscoBears likes this
I would say it's probably your radius arms. What size tire do you have? My dad has to run a spacer with the 265/75/16s in order to get them to clear the radius arms. I have greater offset wheels and 255/85/16s, and I don't rub on steering lock.
  • TomOwen and DiscoBears like this
  • 1,108 posts
Agreed. Most likely tire lugs on the radius arm.
  • 1,330 posts
Agreed as well. There are steering stop nuts on the swivel balls you can adjust to stop the wheels from turning do far.
  • 6,263 posts
Yeah, my '95 rubs the radius arms at full lock with 33s.  Solution:  just don't turn that tight  :)
  • ROVRMAN2, ndamico, Jethro and 1 other like this
+1 to tire, radius arm. Easy to fix, bolts on opposite hub assembly limit the amount of travel, back them out until.tires don't rub. (works up.to a certain size e.g. Chucks 265's need spacers (?) but this works for my 245's...).
DiscoBears
DiscoBears
  • 99 posts
Any pics of the location?
Hey Matt,
Sure, here is driver's side which adjusts lock towards passenger..
And here is Passenger side which is controlling lock towards driver's side...
By backing these out they will decrease the travel of the steering by hitting the stops. Adjust so that the rear of the opposite tire clears the radius arm...
Easy fix - instant gratification.  have fun!
  • Jethro and DiscoBears like this
DiscoBears
DiscoBears
  • 99 posts
Hey Matt,
You rock thanks
  • TomOwen and Jethro like this
Timbo
Timbo
  • 150 posts
  • El Dorado Hills, CA
  • 1994 Range Rover LWB
My rrc's currently go 255/70's on and are also rubbing on full lock. you should be able to confirm that it it this, as you should be able to see the rub marks as a nice shiny bits on the arms behind the wheels.
My Tires are due a change and am planning to move to narrower 245/70's to help, but will prob need to adjust the stops as well.
