LR3/D3 pads/rotors
20 replies to this topic
  • 345 posts
I have done pad changes before no issues, but she is due for rotors as well this time... goodbye rust!
The only problem I am going to run into is the EPB inside the rear rotors. I know Colin has done one or more of these but CT has been quite busy lately, and they're going to help with experimenting on front differential bearing swaps. Colin by the way if you're reading this how did you manage it the last time? I forgot.
Is anyone around that has done these in driveway? How easy or impossible is the EPB adjustment?
I have Bodsy's brake bible already. Looks rough.
Going to try Akebonos and OEM rotors.
Thanks for reading.
EDIT: doing spark plugs too, do the NGK OEM ones come gapped correctly? Do not have a tool here.
Edited by DiscoDavis, 02 May 2016 - 07:07 PM.
  • 209 posts
Ngk should be gapped - the fine platium tips should not be gapped with the old style tool anyway - easy to damage the tips. I used the champion plugs from atlantic british on mine ... No problems. Rear plug on driver side is a bit of a tight fit (remove the heat shield - it levers up with screw driver around mounting points)- do that one last - when you have some experience with the easier ones ...
  • 345 posts
Thanks. Did you get the NGK (G-part number) plugs? This is what I have queued up for the next order.
https://www.roverpar...Parts/LR005253G
William Stephenson
William Stephenson
  • 76 posts
  • San Francisco
  • p38a 4.6
Install new rotor. Adjust shoe until it locks the rotor
Back off 10 clicks
Rotate rotate and find the (I believe 4mm) hex bolt
Loosen 1/4 turn
Smack the drum surround part of rotor with a soft rubber mallet
Tighten hex bolt.
Re-install adjustment cap
  • DHappel and DiscoDavis like this
  • 6,154 posts
Back off 10 clicks
Loosen 1/4 turn
Tighten hex bolt.
Good to know.  I don't need rotors but I may need to adjust my parking brake as it made a really unpleasant screeching noise the last time I (well, Michele) used it and didn't want to release until we pulled the battery.  I've been avoiding it ever since.
  • DiscoChef and DiscoDavis like this
DiscoChef
DiscoChef
  • 1,258 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • '63 109 2A Regular
  • 95 LWB Sold
  • 95 LWB, '67 109
Thanks for reading.
Spark plugs come gaped already. I have the extra long socket you need to remove the plugs, you're welcome to borrow it if you want.
Ive done front rotors (easy) but not the rears. Good luck!
  • DiscoDavis likes this
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
1995 LWB RubiconReady, SOLD
1998 D1, 4.6 Relocated to KY
1992 SWB Da Yeti. Dusy Ready
  • 345 posts
Enrique, yes please! I was going to have to hunt down a socket. I can swing by after work. Tomorrow or later this week?
DiscoChef
DiscoChef
  • 1,258 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • 95 LWB Sold
  • 95 LWB, '67 109
Tomorrow
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
  • 1,321 posts
Where do you buy pre-gapped plugs? I've always had to gap mine, and I'm pretty religiously NGK plugs. At the minimum, I would want to verify that they are properly gapped and didn't get damaged/misadjusted during transport.
  • 345 posts
Back off 10 clicks
Loosen 1/4 turn
Tighten hex bolt.
William, thank you!
Tomorrow
Sweet! Mexxis?
DiscoChef
DiscoChef
  • 1,258 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • 95 LWB Sold
  • 95 LWB, '67 109
I get my plugs at Monument parts in livermore. I always check the gap and they are consistently right. I forget the exact measure
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
  • 345 posts
Enrique, consider me uninformed, what tool do you use to check the gap? Grabbed plugs from Cole European last night.
Pads ordered, Akebono EUR1099, EUR1098
Rotors ordered, OEM from Rovers North (with spacers, locater screws etc.)
Did anyone have a problem getting the spark plugs or coil packs out, ripped boots, corroded threads?
Grabbing mexxis for dinner tonight! I'll leave work sometime after 5pm
  • 1,321 posts
It's called a gap gauge. You can also use feeler gauges if you already have some.
This is the most common type:
http://www.amazon.co...EFM1A16MCHEF141
  • 345 posts
Ah wow of course its that thing. Never used one before, seen everywhere. thanks chad
  • 209 posts
Just be careful you don't damage the platinum tip ...   from NGK themselves...
https://www.ngkspark...ew-set-of-plugs
I used Magnetic plug socket from Kragen - makes it much easier to get the things in/out of the holes - and you will need a 6" and shorter extension and possibly a swivel bit (between the two) in some places if I remember right ...
  • 345 posts
the NGK ones I picked up from the dealer are marked IR, I am assuming iridium. No issues from damage with a gapping tool?
And Enrique was kind enough to loan me his socket, so I've got the tools part covered now! Thanks again Enrique!
Hunting for a swivel today, and two 3" extensions
Edited by DiscoDavis, 06 May 2016 - 08:12 AM.
BEAR
BEAR
  • 696 posts
  • Concord
I just did front pads and rotors with Dons help last sunday. well Don did most of the work. I got the oem rotors from atlantic british and the green pads and brake sensor on amazon. BSing included it only took us about 2.5 hours. Thanks again Don!!!
Concord CA,
2006 LR3 SE with HD
"waiting for an adventure"
  • 6,154 posts
...ain't no thing
  • 345 posts
What I'm worried about is the rear rotors... lets see how that goes.
Volkov
Volkov
  • 226 posts
  • Vallejo
  • KK6UUO
  • 1977 Land Rover 101FC
http://media.disco3....ompressPics.pdf
This might help you out
