RRC Door locks... What the hell
15 replies to this topic
Justin
Justin
    NCLR Marketing Director
  • 554 posts
  • 1991 Range Rover GDE
  • retired-1996 Discovery
  • sold-2001 Range Rover
So Im beyond confused....
Anytime I lock my RRC via the Drivers Door lock the lock will go down, only to pop right back up seconds later. The latch and everything else works and looks to be hooked up together. Could it be a faulty BECM?
Has anyone else had this issue?
When you say you are locking it from the drivers door, are you talking about using the key from the outside?
I have not had this issue, and sadly lack a RRC, but I'm assuming the systems are fairly similar to a D1. If I try to lock the doors on a D1 with the drivers door open, it will lock and then pop up a few seconds later. I would check to make sure the door switch is good. Seems like the truck thinks the driver door is open.
Edited by lilcrawler, 04 May 2016 - 09:01 AM.
  • AdvRovr likes this
  • 1,366 posts
Correct me if I'm wrong, but I didn't think the RRC had a BCM, I thought management was distributed through individual controls (window ECU, seat ECU, central locking ECU, alarm ECU, etc).
I agree with Tyler that it's the same behavior as locking with the door open, so I'm guessing faulty door switch makes the truck think it's open. Is your dome light on?
At least on the DII it is a different switch that tells whether or not the door is closed vs the switch that activates the dome light. I'm not sure with the D1 or RRC, but I would expect it would be similar, but I may be wrong.
Edited by lilcrawler, 04 May 2016 - 10:12 AM.
Justin
Justin
  • 554 posts
So...
Its definitely not the LHF Side, when ever I lock the doors via pushing down the RHF Door lock switch and than I lock the doors with the key from the LHF side it will lock fine. Thus leaving me to believe its a stuck lock on the RHF side.
Luckily I'll be able to atleast drive it and lock it for the night (have my fridge, powertank, etc in the trunk) so thats nice.
astateofmike
astateofmike
  • 2,307 posts
  • 1988 Range Rover Classic
  • NCLR 004
Mental note, free fridge powertank available one night only :)
  • Justin, AlysonH and AdvRovr like this
So...
Yeah. It could be. I pulled the door card off for an adjustment/repair on the locks on the D1, and when it went back together something wasn't aligned right so the lock stuck. Once I readjusted the lock it worked fine.
It could also be the solenoid failing to provide enough torque to "tip" the latch over, which may result in a failed locking state. You could pull the door card and see how things are moving in there.
  • 963 posts
just lube the door latch mechanism in the jam of the door & that will help... also spray wd40 into the key hole on the handle
If that does not cure it! replace door solenoid
Edited by SLOHybrid, 04 May 2016 - 01:31 PM.
  • 1,295 posts
Jared and I had so many problem with RedRover's locks that I think he finally just pulled the fuse and we lock each door individually now.
  • DHappel likes this
I did that, and it made things worse. WD-40 caused dust to stick in my latch like glue. I would use some sort of grease, or simply go with a good cleaning.
  • 6,464 posts
Given the option, I'd prefer my RRC have manual seats and locks.  I'm OK with power windows though.   Less weight, less complexity, less to go wrong.
Timbo
Timbo
  • 150 posts
  • El Dorado Hills, CA
  • 1994 Range Rover LWB
Agree - WD40 is NOT a lubricant, and will leave a sticky residue.
Was designed for water displacement (hence the name)
Edited by Timbo, 05 May 2016 - 09:08 AM.
  • 1,366 posts
Given the option, I'd prefer to have power seats, locks, and windows that just worked properly...
This..... x1000.
  • 963 posts
Just try it Justin!  it works
Thanks for the education on WD40 guys :rolleyes:
Justin
Justin
  • 554 posts
Lubed up the RH side and LH, its all working now.
I guess I should just be happy its working and not question it lol
That's what we're here for. :)
  • erinw.rrc likes this
