Anybody have a TR F/R bumper?
5 replies to this topic
BEAR
BEAR
  • 701 posts
  • Concord
So I'm in the market for a front and hopefully sooner than later a rear bumper. I really like the good clean look, reliability and a proven company like ARB. I have heard some issues about the bumper for the LR3 though, such as a small hole for clutch switch and possible bending on the sides under load? On the other hand I like to be different and I really like the Idea of supporting a local ( CA ) business and going with the Tactical Rovers bumper plus its less expensive and we get a discount but I have never seen one in person. I was wondering if anyone knows someone who has one or could just attest to them if they have seen one in person. I understand there is a ARB group buy so that may change things depending on price.
Concord CA,
2006 LR3 SE with HD
"waiting for an adventure"
  • 783 posts
The TR has a better approach angle for sure. But I think it's really based personal preference.
  • 6,440 posts
I've probably told you my take on it all before but I'll cover it again.
I'm running an ARB.  It did not fit well and required mods to 'bolt on'.  ARB's response when asked during installation came down to 'uh...we don't know'.
I chose it over the TR at the time because like you I hadn't seen a TR in person and wasn't sold on it based on the pics on their website.  I've since had a chance to see one in person last summer at the Sedona rally and liked it fine.
Comparing the two, the TR has better approach angles (the ARB sticks out a lot) and far superior winch access (the ARB has a very tight hole you have to reach through to access the clutch lever).  The ARB however is supposed to work with your stock air bags where I doubt very much TR did any testing to see how their bumper would react to them so take that as you will.   The ARB also uses the stock washer fluid tank and headlight squirters while the TR does not have provisions for the squirters (I think) and requires you to source your own smaller washer tank.  I don't know it for a fact but I also believe the TR is stronger than the ARB when it comes to outright abuse in the rocks.  That's in keeping with their respective designs as TR is a more hard-core company where ARB is more of an expo type company.
Were I doing it again I'd order the TR without a second thought.
You've probably seen this, but here's a video (part 1) showing a TR being installed.  The ARB is at least as complicated if not more so, and is harder to install in that you bolt the winch to the bumper then offer the whole thing up as an assembly, making it quite heavy.  I used my cherry picker to do the lifting and still had 2 people to align it before bolting everything in place.
  • BEAR, yarrover and Jethro like this
BEAR
BEAR
  • 701 posts
  • Concord
thanks Don. Yeah after hearing you talk about it is what made me really consider the TR. I just wasn't sure about its construction and I have heard some negative things about the TR's powder coating.
Concord CA,
2006 LR3 SE with HD
DiscoChef
DiscoChef
  • 1,265 posts
  • KI6QBY
  • !998 D1
  • '06 LR3
  • '63 109 2A Regular
  • 95 LWB Sold
  • 95 LWB, '67 109
The powder coating on the ARB bumper is pretty shoddy too! The corners where two panel meet, tend to blister and create corrosion within. I sanded and repainted many spots to prevent further corrosion
Enrique
KI6QBY
1992 RRC SOLD
1995 LWB SOLD
1995 LWB RubiconReady, SOLD
1998 D1, 4.6 Relocated to KY
1992 SWB Da Yeti. Dusy Ready
  • 6,440 posts
I can't say I've had any real problems with the coating on my ARB.  The only rust I've got on it is where I pushed a tree aside and rubbed through the coating on one corner (not bad) and some scrapes on the bottom from pushing it up rocks.
