Well there's your problem
6 replies to this topic
  • 6,422 posts
Pretty easy to find the issue here.  The real question is Why?
IMG_20160921_151512360_HDR_zps1fcelmoi.j
Dropped? Hit something on the way down...?
  • 1,362 posts
Wow. Could that be from receiving too much charging current for too long?
Rum_Ham
Rum_Ham
    The Dude
  • 61 posts
  • Napa, CA
  • '00 Disco- Oxford Blue
The answer is simple really, God hates Interstate Batteries...
In all seriousness though, I have never seen anything like that in my experiences. I have seen batteries explode but never like that. Most impressive...
Dave
Born ~ 1985...  Died ~ In your arms tonight...
  • 6,422 posts
I think you're onto it here.
First, this is a standard flooded battery.  The owner thought it was an AGM because all the other batteries on that charger (generator, both engines, bow thruster) are AGM.  The boat did not orriginally ship with AGMs so I assumed somebody had set the charger to AGM when they changed and forgot about this one flooded battery.  Upon checking, I found they had actually set it for Gel batteries.  AGM batteries use a slightly higher charging voltage than flooded.  Gel are higher yet.   I think this is the root cause of the explosion.
That and Interstate.   :)
I've only seen one other battery explode like this.  It was a flooded battery that was ignored for a very long time and left to run dry though the charger was still running.  It exploded in the bilge with nobody around.  This one let go when the owner hit the pre-heater for the genset (it's the gen battery).  I bet it made a fun sound....
  • 2,088 posts
I know the answer to this one.  I don't have time to type the full explanation, but I saw the same thing many years ago on a rotary UPS system with a large number of 6V block in series (totaling over 500V).  I was called out by a customer and found pieces of battery over the other side of a room (about 25 feet across) and there was an 8' high switch cabinet in between the two.
Analysis showed that a "lead tree" had grown across the plates, causing a low resistance path that acted like a filament when current was drawn (in that case it was when the mains failed and the system went to battery, so pulling 200+A).  The filament ignited the hydrogen and that was the result.  I never understood where the oxygen came from for the explosion, but it was obviously enough to split the case and then there was plenty of oxygen!
I would guess your one "exploded" when the starter was cranked, or some other higher load was applied.
  • 6,422 posts
You may be correct.  It let go when he hit the pre-heater for the diesel genset.  Not as much draw as the starter, but pretty good.  I'd guess at least 50 amps.
I'm heading back down to that boat tomorrow to check on a different charging issue.  Seems both engine alternators are charging at 16v for some reason.  I find it unlikely that both regulators failed at the same time so I suspect something else is going on.
