LR4 Waterpump - How to check for failure?
- - - - - LR4 Discovery water pump clamp loose drip drip drip
11 replies to this topic
  • 1,270 posts
So, how does one check if the water pump on an LR4 is going out?  First, I've check for a coolant leak, I have one, but not attributed to this.  It's leaking from some hose clamps that were use to modify the lines to the rear of the vehicle during the tire and spacers modification two years ago.  Will look into this separately.
Secondly, there is a low rumble vibration at idle, that is intermittent, but I haven't determined where it's coming from yet.  Anyway, my goal is find out what this noise is and where it's coming from.
Thanks,
Erin
  • 745 posts
Mine just went out, started leaking from the front of it. Started off really slow then when leaving last month's DITD the reservoir was empty.
Not sure on a noise with these as it's definitely near other noisy elements.
I have learned that it is definitely an 85k mileage item give or take 5k miles.
So look at your mileage too, I was lucky and warranty covered it. Total cost was $1500.
Yup, while there are folks here that know for more than I on this, the old "weep the pour" is an initial indicator, which generally get's water in the bearings so it begins to make noise, vibrate, etc..  The only thing not mentioned is if you can "wiggle" the fan. Since it is mounted to the pump shaft, it could give you an indication of the bearings...
Good luck Erin!
  • erinw.rrc likes this
  • 6,288 posts
A failing bearing in the waterpump will cause a 'rumble' or 'grumble' sort of noise.  It's generally not intermittent though.  It will be easiest to hear from outside with the hood up and will change with engine speed.  The tough part is anything being turned by the belts could also be making that sort of noise (alternator, idler, air con pump, etc) so it's hard to isolate it.  I have a mechanic's stethoscope that helps but isn't 100%  The old-timer way to do it was to take a long screwdriver and place the end against the part you suspect and the hold the handle against your skull just behind the ear.  The noise makes a vibration that gets transmitted up the screwdriver and directly to your ear in the same sort of way a stethoscope does, just not as well.
Additionally, any bearing can make that sort of noise when failing.  Wheel bearings in particular are a common noise maker when they start to go.  They are often a little louder when turning one way to the other since you load each side a bit more when turning.  A wheel bearing will change noise with road speed and not make any difference with engine speed.
Another possible source could be a driveshaft.  Yet another is a differential.  Both of these would be road speed dependant instead of engine speed.
There's a lot of things it 'could' be, and without hearing it it's pretty much a guess.  Even if I do hear it sometimes it's still a guess!
(Here's where I'd like to think doctors are more precise than mechanics, but from what I've heard from some of them they too are just taking an educated guess far more often than you'd like to believe  :blink: )
  • 1,270 posts
My truck has 53k miles and is out of warranty.  So this will an expensive fix if that's what it is.
  • 1,270 posts
Good luck Erin!
I will check this when I get home.  Thanks Tom!
  • 3,453 posts
This sounds like the same tech used for those bone-conduction headphones that are for sale now.
Old tech becomes new tech....
  • DHappel and erinw.rrc like this
  • 2,076 posts
Erin,
I hear RoverWare.US can do them very cost effectively .... which engine do you have in that thing?
  • 1,270 posts
Erin,
Graeme,
It is a 5.0L V8 Jag engine. However after troubleshooting with a coworker after work, we think the noise is coming from the rear of the truck. Still not sure what it is though. Might take it to Don's this weekend and see if we can figure it out. I will let you know if we need any parts.
Thank you!
Erin
  • 1,108 posts
You can pick up a mechanics stethoscope from harbor freight. It's inexpensive and if you're not trying to use it all the time it will do just fine. You'll want to touch it to the case of each rotating piece like water pump, alternator, power steering pump, belt tensioner, ac compressor and any other Land Rover magical device being belt driven. The loudest one will be your culprit. Don't forget to check for debris fouling the fan like sticks and leaves and such and also take a look at your power steering reservoir level. It's likely something you can fix yourself.
Gotrovr
Gotrovr
  • 1,298 posts
the sound is Lucas saying hello
Will
'05 LR3 HSE "Donkey"
'16 LR4 HSE  "Perseus"
Building a life journey one puzzle piece at a time
  • 1,270 posts
So my waterpump is fine... so far.  Leak turned out to be coming from the rear.  The hose was coming loose.
  • Rum_Ham likes this
Also tagged with one or more of these keywords: LR4, Discovery, water pump, clamp loose, drip drip drip
