Flashing brake dash warning light!
- - - - - Range Rover RRC brakes warning lamp LWB
3 replies to this topic
Timbo
Timbo
  • 150 posts
  • El Dorado Hills, CA
  • 1994 Range Rover LWB
I knew it was too good to last - the lwb' been running trouble free for far too long, so now it's payback time!
Started today, but driving along and as soon as I hit the brakes the warning light will flash. Never stays on.
(Abs and tc are a pem lighting fixture :)) .
Checked for fluid level - (did top it up the other day as it was low but was fine today) and also leaks - can't see any, and pedal feel does not seem to have changed.
Could it be that the accumulators finally given up the gost? Pump does take a long time 30 sec to do the initial charge at startup, and seems to be cycling very briefly every so often with ignition off.
Other thought - could the rubber washer at the top of the master cyl reservoir be bad and letting pressure out as I did undo that when I topped the fluid up?
  • 2,077 posts
.... Pump does take a long time 30 sec to do the initial charge at startup, and seems to be cycling very briefly every so often with ignition off.
..... Other thought - could the rubber washer at the top of the master cyl reservoir be bad and letting pressure out as I did undo that when I topped the fluid up?
Tim,
Pump cycles with ignition off?  You have a problem then.  One of your relays is stuck.
The reservoir is not pressurized, so this isn't the issue.  You can run perfectly well without the lid on (although you'd spill fluid).
Timbo
Timbo
  • 150 posts
It's not continuous. Just a quick topUp pulse
I should rephrase - ignition on / engine off!
Should check the relays, as there is one that's cycling away under drivers seat.
Edited by Timbo, 09 February 2017 - 12:48 PM.
  • 1,110 posts
on my p38 the flashing brake light means low pressure warning in the brake system.  My fix was a replacement accumulator.
Also tagged with one or more of these keywords: Range Rover, RRC, brakes, warning lamp, LWB
