LR3 Leaking in California Storms
- - - - - water leak lr3 storm
20 replies to this topic
KSuttle
KSuttle
  • 488 posts
First of all - I've re-upped our membership and hope to join y'all soon on a trip. The Suttle Shuttle hasn't seen true off-road in a few years now.  But on to my issue at hand.
My 2005 LR3 is collecting interior water primarily in:
  • The front passenger footwell
  • The door sills under the trim (where wiring harnesses are)
  • The seatbelt roll/retractor in b-pillar is soaked
I have already checked/replaced the following
  • replaced failed driver side 90 degree drain connected in the footwell (about 1.5 years ago when I had a water crossing INSIDE my Rover)
  • all 4 sunroof drain tubes clearly evacuate water from the sunroof tray (I can pour cups of water in the tray and it evacuates from all 4 tubes rapidly without water build-up in vehicle)
  • the cabin/pollen filter & blower area behind the glovebox is completely dry, so no apparent windscreen cowl issue
  • zero leaking from the headliner anywhere that I can feel/detect
  • have ordered the A-piller exterior trim repair kit just in case
Any other ideas where this water could be coming from?  What seems really weird to me is the fact that the seatbelt at the retractor (in the b-pillar) is literally soaking wet.  Could the roof rails be leaking?
-Kevin
Kevin Suttle
KJ6IBK
"His" - 2005 LR3 aka "The StormTrooper" - Coil Suspension, Cooper Zeon LTZ 285/60R18's, RS Stage 1 Sliders, Safari Snorkel, Hannibal Roof Rack
"Hers" - 2007 LR3 SE7 aka "The Adventurer" - BFG 265/65R18's, RS Stage 3 Sliders, ARB Deluxe Winch Bull Bar, BajaRack RTT Roof Rack
  • 2,029 posts
-Kevin
Kevin,
Good to hear from you again .... it has been a while.
Is it rain water or aircon condensate?  Both will be worse after rain.  The b-pillar would indicate rain not aircon, but the rest could be either.
Timbo
Timbo
  • 150 posts
  • El Dorado Hills, CA
  • 1994 Range Rover LWB
How about the doors themselves?
On different cars (not lr3) I've had multiple issues with the sealant failing on the vapor barrier behind the door card, and it letting water in soaking the footwells
KSuttle
KSuttle
  • 488 posts
UPDATE
Thanks Graeme - it is not air-con condensate.  I should have mentioned that I checked that too.
I poured water over the roof rails and BAZINGA...water flowing down the b-pillar.  I've pulled the roof rack and rails.  I found plastic washers and what appears to be cracked sealant/caulking of some sort around the nuts welded to the roof - it is under the layer of body paint and clear coat...so it is something from the factory. The material is relatively soft...so I'm thinking its not the weld itself but some sort of sealant that's cracked over the course of 12 years.
 I'm going to clean it all up, dry it with a blow dryer, apply my own caulk and put it all back together again before the rain starts up to see how it does.
Edited by KSuttle, 18 February 2017 - 01:26 PM.
  • RedRover and Jethro like this
Kevin Suttle
KJ6IBK
  • 2,029 posts
UPDATE
Kevin,
Glad you seem to have found it.  10-12 years is about when caulking, plastic and rubber parts start to complain about their age, so we'll see more LR3 owners with leaks ....
KSuttle
KSuttle
  • 488 posts
Work is done for the day. Now we wait to see what happens in the next storm.
Here are some pictures of what I found (not sure why this forum software is rotating them):
The roof rail on my other LR3 has little caps over the screw holes...this LR3 does not.
Attached File  IMG_8495-2.JPG   84.68KB   7 downloads
You can see the cracked stuff (sealant?)
Attached File  IMG_8497.JPG   94.94KB   7 downloads
You can see more cracked stuff (sealant?)
Attached File  IMG_8499-2.JPG   105.64KB   7 downloads
Everything apart...
Attached File  IMG_8501.JPG   100.59KB   7 downloads
Edited by KSuttle, 18 February 2017 - 07:09 PM.
Kevin Suttle
KJ6IBK
KSuttle
KSuttle
  • 488 posts
Good news and fingers crossed...as of 7:30am, no leaking after last night's rain.
Kevin Suttle
KJ6IBK
  • 3,401 posts
Interesting -- thanks for sharing the photos as it helps visualize what you were describing.  Certainly looks like factory sealant that's starting to crack badly.  Good luck with your fix!
lithium1330
lithium1330
  • 511 posts
  • KM6FDG
  • Defender 90 NAS #0032
I have similar cracks on my D90 rain gutter... and others suggests cracks like that allow water to seep through.
Others suggest best thing to do is to clean them out/well with alcohol, apply body seam sealers (not silicon nor RTV) to fill these cracks, then paint over them.
  • 2,029 posts
On a D90 there are usually larger holes in the floor, to let the water out .....
  • dcproven, JFuller, AlysonH and 2 others like this
Teds
Teds
    WJ6SPK
  • 900 posts
  • 2001 Range Rover
  • 2009 M1101 trailer
Good to hear from you Kevin. Hope it is sealed up. Will check our LR3 soon. thankfully, we park it in a garage overnight, but the A pillar blew off on the freeway last week in the storm!
  • 6,093 posts
Ha!  I had the same thing happen in Sedona a couple years ago!  It was the driver's side and only let go partially so I was able to stick my hand out the window and hold it in place until I stopped by a dealer and picked up a new one.  I found mine had some of the mounting tabs previously broken and replaced by double-stick tape.
  • 3,401 posts
There you go again, Graeme -- waxing poetic about the revered Defender, but you fail to acknowledge that many Rovers in the stable are offered that very same option.
RRCs also come with the large (and auto-sizing) water drainage system:
Attached File  rrc_floorpan_rust.jpg   102.77KB   4 downloads
I've heard the feature is quite prevalent in the UK.
  • DHappel and Rum_Ham like this
BEAR
BEAR
  • 694 posts
  • Concord
So I'm having a similar issue. My driver side floor board is getting soaked when I drive in the rain. I messed up when installing my sliders and cut a piece of the plastic wheel well on that side off. Not sure if that would cause the problem though.
Concord CA,
2006 LR3 SE with HD
"waiting for an adventure"
  • 6,093 posts
Unlikely to be slider/wheel well related.  My first bet is always sunroof drains, though it's worth looking into the roof rack mounts as above.
KSuttle
KSuttle
  • 488 posts
With things like RTT's and jerry cans during overland adventures I'm sure those rails got torqued a lot.
One of the original torx screws was sheared off by the previous owner and replaced with a hex bolt. I also noticed on inspection that one of the torx screws ripped through the bottom of the rail.
Kevin Suttle
KJ6IBK
BEAR
BEAR
  • 694 posts
  • Concord
Well I've had my sunroof drains clogged before and water was leaking out of the dome light in the front. I guess the clog could be lower but there's a lot of water that gets in there.
Concord CA,
2006 LR3 SE with HD
  • 6,093 posts
Do a search on any of the popular Rover forums for LR3 sunroof drains and you can find pics.  Basically the drain comes down the A pillar and through a junction at the firewall.  Sometimes that junction will fail, letting water get into the passenger side footwell and soak the carpet and wiring looms.  Usually the culprit is the very end of the tube back behind the fender vent getting clogged and backing water up.  You can just snip the end off to keep it clear, but often the vent breaks one or two of it's mounting tabs when you remove it.
  • BEAR likes this
KSuttle
KSuttle
  • 488 posts
Leaking again. Roof rails solved the b pillar leak, but I've still got water coming in slightly under the drivers and passenger's carpet. Waiting for the dealer to get the a pillar cover repair kit in stock.
I don't think it's the cowl as there is no water in the pollen filter or blower.
Kevin Suttle
KJ6IBK
  • 6,093 posts
The cowl doesn't usually cause water inside, more likely to cause issues with the wiring behind the battery.  I think that may be the control module for the transfer case?  Can't recall right off.
I know you found the joint where the sunroof drain goes through the firewall rotted and replaced it.  Did you also clear out the end of the drain behind the fender vent?  That's the most common source for a wet carpet.
Also tagged with one or more of these keywords: water leak, lr3, storm
