terra firma heavy duty springs
- - - - - lift D1 coils terra firma OME
7 replies to this topic
seldomwright
seldomwright
    Seldomwright
  • 35 posts
  • oakland
  • Lifted 99 Disco 1
Back for more of the collective wisdom of the forum.
So, '99 D1 SD... recently DIY swapped the rear medium duty Old Man Emu coil springs for heavy duty Terra Firma rear springs combined with a one inch spacer.  Reason being the 32" tires scraped the camel cut body work when jammed up into the wheel well.  So all's well, except that one side seems to have an inch more lift than the other.
What am I missing here?  I've double checked that everything is seating properly top and bottom on both sides.  Is there some coil spring twist / rotational logic that I'm not seeing?  It's a Discovery 1 so the springs don't have to seat any particular way, the coils are ground flat top and bottom.
What could be the issue?  One shock not compressing all the way?  The shocks were not touched during the Coil swap.
Thanks!
  • 2,077 posts
Thanks!
The problem is in the first line .... TerrorFarmer .... Their quality control is not very good.
  • 747 posts
I'm running the same springs and I notice my passenger side has a lean towards it. I have assumed it is the weight of the tire that is more to that side. I haven't had anyone​ look at with me in there yet to see if it's level.
Is that what you are noticing as well? Could it just be they haven't fully seated?
There is also Graeme's comment, whereby people don't have the highest opinion of TF. I have recently added a few of their products but it's too early to have an comment on them.
For the price I can see value as I'm still learning how to build/setup a rig so very possible I could change stuff out as I get better understanding of the rig and my own abilities.
I do like the gas can holder, where did you get that from?
  • 6,312 posts
I can't say that it's the springs specifically, but there's an obvious way to test....
seldomwright
seldomwright
    Seldomwright
  • 35 posts
  • oakland
  • Lifted 99 Disco 1
Ha Graeme! That sucks, hope not.  A whole inch sounds crazy for QC issues.  That would mean if i swapped them left and right the extra inch would be on the other side right? Hm.  Is that what you are suggesting DHappel...?... or take off the spare and re check?
Jethro, yeah it's higher on the driver side.  Thanks on the tank holder looks, made it DIY style based on other's designs.
While I have you guys here Graeme  and DHappel ... two more questions.
1- should OME medium duty FRONT coils be compressed to about 10 inches?  Or does that sound like they are dead?  They're super rusty.
2 - can I put my medium duty REAR OME's on the FRONT?  It seems it would lift it 2 inches to about 12" total coil height under load.  Horrible idea?  Or just a cheap ass idea?  I have the HD TF front springs coming in the mail.
Anybody else going down to Hollister SVRA this weekend for the Molina Ghost run?  I'll be there.
Thanks guys.
  • 2,077 posts
Many people put standard rears in the front, so medium rears would probably be fine, if a little stiff, and likely give you about 2.5" of lift without a winch. Try it and see. Doesn't take long.
BTW, the original LR springs we're handed, left and right, because the vehicle weight is different on each corner.
  • 6,312 posts
Yes, I was suggesting swapping the springs side for side and seeing if the list follows.
As for running rears in the front, my '88 RRC has rear stock springs in the front and a small lift spring in the rear giving it about 1" overall lift.  How much/how stiff doing that with your setup would be I couldn't say but it should be doable.
  • 3,885 posts
OME springs are sided like the factory springs. Maybe TF has done that but it's not mentioned? Dunno.
So I'm digging deep, deep into the way back machine for these numbers.
https://discoweb.org/oldsite/lift.htm
https://discoweb.org.../suspension.htm
Also tagged with one or more of these keywords: lift, D1, coils, terra firma, OME
