steering tweek
15 replies to this topic
  • 5,953 posts
Last weekend I got sloppy (talking on the radio and looking in my mirror instead of where I was going) and hit a pretty good rock with the passenger front tire.  After this, I noticed the steering wheel was now about 1/8th turn off center.
I assumed I had bent the drag link bar from the pitman arm to the knuckle, or maybe the bolts at either end where it's attached, but none of these areas appear damaged and frankly I'd be surprised if they were given the materials they are built from vs how hard the hit was.
There is no difference in the way the truck drives so the tie rod (alignment) isn't likely affected.  But something changed or the wheel would still be straight.
I'm stumped - I don't think the steering box is damaged as it feels fine going down the road/trail.  Is it possible I've jumped a spline on the input U-joint?  Again, I wouldn't expect that give the hydro assist on this rig.
Any other thoughts?
  • 938 posts
Probably something to do with all the heim shite you have on there! :P
doubt you skipped a tooth on the box as the drop arm would literally need to be totally loose to do that.
PITA to get that wheel straight without removing it and doing it the correct way @ the rod ends... I just did it this weekend & still not right :unsure:   goes down the rd nice though now
  • 5,953 posts
I can always take it apart and adjust the rod; at least I hope so as there's not a lot of adjustment left in it.  But that doesn't tell me what changed to necessitate the adjustment as she used to roll down the road with the wheel straight ahead.  I'd like to figure out the 'why' before just changing things.
  • 2,009 posts
Did you remove the two rose joints (aka Heim shite) and check whether that overly burdened pin is bent?
  • 5,953 posts
Not yet, but it certainly doesn't look bent.
I ordered some safety washers for the single sheer heims and figured I'd pull it apart at that time.
  • lutz likes this
  • 2,009 posts
It would only need to be a tiny amount, about 1/16" from top to bottom from what you described.  I expect if you lay it on a flat plate to check, it will be slightly curved.
Edited by GraemeWare, 18 July 2017 - 07:07 PM.
  • 5,953 posts
Now you've got me curious.  I'll take it apart soon enough.
  • 938 posts
On another note Don I need to copy your Ram steering setup for my 94 LWB crawler... is it a Todco setup?
  • 5,953 posts
PSC ram to a P38 (?) pump.  Not perfect - seems to have enough pressure but not enough volume as fast turns like a parking lot will cause it to lag and get heavy.
  • lutz likes this
  • 664 posts
Do you know if he's still in business? Website is static and so it's hard to know.
  • 2,009 posts
Or go for a Gwyn Lewis set-up.  I hear RoverWare.US are a distributor for them ....
  • 664 posts
Do you have a link?
  • 2,009 posts
Do you have a link?
No, I don't, but it looks like this.  No stock at present though.
hydro-assist-kit-glhak-gwyn-lewis-4x4-01
  • 664 posts
Okay, okay...I'm interested!
  • 1,090 posts
Graeme. Don't see it on the site. Price?
  • 5,953 posts
Steering update:
I decided I'd have the alignment checked.  I noticed it had a *very* slight pull to the right, which would fit with the steering wheel now being about 1/8th turn to the left.  The pull was so little though that it could have been there before and I just didn't notice it.  Or just the crown of the road, etc.  Hard to say.
It came back with toe out (I forgot to write down the spec) which I found odd.  Most vehicles are set up with a bit of toe in stock as it aids stability on the highway.  The only time I've used toe out was for an autocross car that I intentionally wanted to be 'darty'.  It wasn't much but I had them re-adjust it to be just slightly toe-in.
The bad part is the rear also had toe-out.  This should of course be 0 and being a solid axle it means there's some bend in the housing.  There's not really a fix for this other than replacing it.  I have a spare, so maybe I'll swap it over someday.
The current specs are front left -.01*; front right -.03*; total -.05* toe in
Rear left is -.13*; right -.25*, total of -.39*  toe out.  This explains why the truck feels a little unstable on the highway.
After the adjustments (which were so small they didn't charge me for - thanks Mario at Les Scwab, former D2 owner) the steering is almost back to straight.  It's still a few degrees to the left but not enough I'm going to mess with it.  The rear axle could easily be accounting for this.
